Question about HP PSC 1315 All-In-One InkJet Printer
Sends out blank pages, stops and clicks loudly and doesnt print
Sends out blank pages, stops and clicks loudly and the paper sticks in and will
not print. the same problem using the coppier.
thanks. [email protected]
  • mountamberin Mar 26, 2008
    No, these don't work, what a piece of junk,
    and what a difficult time you make this proceedure. Next time ? HP? Never.
    Genius:
  • 1,665 Answers
Ink jes must be blocked
Posted on Mar 25, 2008
6ya staff
SOURCE:
Printer is spitting out blank pages, when trying to print.
Your laptop and the printer are not communicating correctly.
Sep 20, 2018 | The Office Equipment & Supplies
No print only a blank page comes out
Wrong printer drivers for your computer or else they did not install properly. Also blank page may mean you are out of ink/toner.
Aug 19, 2014 | Office Equipment & Supplies
Inconsistent printing
In the printer's dialogue find the print pages number. Print page from/to and select 20 pages chunks. In effect print only part of the document at a time. Add all chunks together in one pile. Work around I know, but it works.
Aug 02, 2017 | Brother HL-2130 monochrome laser printer...
Good morning..my problem for hp k7100 need to reset.
i have this hp officejet k7100...
it doesnt recognise the computer when i click on add a printer, choosing plug and play..
Jan 28, 2011 | HP OfficeJet K7100 Photo inkJet Printer
When you send something to print it stops, the attention light blinks red and once you click on the green CHECK button it prints again. Why does it act like its jamming?
  1. Slide the paper-width guide to its widest position, and then pull out the paper tray extender. Figure 2: Move the paper guidesc00648140.gif
  2. Insert plain white paper into the input tray with the short edge forward and the print side down. Slide the paper forward until it stops. Figure 3: Insert paper into the productc00636180.gif
    CAUTION: Make sure the product is idle and silent when you load paper into the input tray. If the product is servicing the print cartridges or otherwise engaged in a task, the paper stop inside the device might not be in place. You could push the paper too far forward, causing the product to eject blank pages.
  3. Slide the paper-width guide inward until it stops at the edge of the paper. Figure 4: Adjust the paper guidesc00636178.gif
    NOTE: Do not overload the input tray; make sure the stack of paper fits within the input tray and is no higher than the top of the paper-width guide.
Nov 09, 2010 | HP LaserJet P3005n Printer
I guyz. my hp officejet printer works very fine as in you send document to the printer but the most amazing thing is that afetr printing and you discover there is no ink on the printer page. Please...
Hello
Before actually printing your report, use the Print Preview function to see how it will look. If there are blank pages, you will see them in Print Preview.
To use the Print Preview function, simply open the report, click on the "File" menu and choose "Print Preview" from the file menu. You will then see your report just as it will look on the printed page.
Scroll through the report for blank pages. If you see blank pages, it is an indication that the data on the report is wider than the paper you are using. You can use your printer properties to change the size of the paper if you wish. If you have access to legal-size paper, you may be able to print the report on the larger paper. If legal-size paper is not an option, you will need to adjust the margins so that the blank pages are eliminated.
To adjust the margins of your report, click on the "File" menu and choose "Page Setup" from the drop-down box. Go to the Margins tab and adjust the margins as needed. It may take a bit of experimentation to get the margins just right; toggling back and forth between Print Preview and Page Setup will make the process faster and easier.
Click on the "Page" tab and choose either portrait or landscape orientation. Changing the orientation to landscape may allow all the fields to print on the same page, thus eliminating the blank pages and saving your paper.
Nov 05, 2010 | HP OfficeJet d145 InkJet Printer
Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Jan 27, 2009 | Office Equipment & Supplies
HP 6210 using double paper?
Try cleaning the rollers (especially in the back door). It stopped mine from jamming. Hope it will stop the double paper thing!
Apr 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
HP PSC 1315 All-In-One InkJet Printer Logo
73 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
