Question about Sharp CV-P09FX Air Conditioner
Drainage i have the sharp portablke air conditioner and i have everything hooked up rite the hose everything it works fine for about 3 hours and then it fills with water and i have to constantly drain it or it leaks every where should i have to drain it every 3 hours or is there something wrong
That is not the problem. These units are supposed to blow the condensate out the exhaust hose. Mine worked that way for a couple of years, when it was just as humid as it is now, but now it won't run a full day without filling. It is broken. I did a "make-do" solution, by hooking a hose permanently to the drain **** (garden hose and a clamp) and raising the unit on a strong platform so the hose can drain by gravity out the window, next to the exhaust duct.
Posted on Jul 14, 2010
  • 674 Answers
The amount of condensate it is producing is dependant on how humid the air is it is cooling. The more humid it is the more condensate you have.
Posted on May 02, 2010
Why do red green and yellow lights flash and unit turns off
This is the unit telling you that you need to empty the water from the collection tank. As an air conditioner functions it removes water from the air. Much of it is discharged in the exhaust air but there is a collection tank that fills up as well.
Hook the hose that came with the air conditioner up to the rear of the unit, the upper discharge port (not the one on the floor), put the end of the hose in a bucket or outside, and turn the valve that surrounds the now-attached hose to "open." Press the power button on the unit twice quickly. it will power up and pump out the water. When it is done flowing turn the valve back to "closed," turn the unit off, and remove the hose. It should now function normally. This has to be done periodically.
Jul 12, 2014 | Sharp CV10NH Air Conditioner
Unit will not run after about an hour until tank is drained -if a container is placed under the unit with plug out the unit will run like. An awful lot of water seems to come out of the unit.
Thing to remember about an Air Conditioner is it is transferring heat, so if you are in a hot humid enviroment you are going to condense more water, which will fill the tank up quicker.
If the tank has a spot to connect a hose to the tank, and you have a drain nearby, might be worth hooking a hose up.
a thought anyways on a fix
But the water is normal
Aug 21, 2013 | DeLonghi CF210 Portable Air Conditioner
I have a Sharp Comfort Touch AC displaying E-1. ??
This is a reminder to clean the air filter. It happens every 720 hours of operation. Here are the steps to get it back up and running:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above EXACTLY.
Jul 26, 2010 | Sharp Heating & Cooling
Water tank fills up every 3hrs
The amount of water that is getting extracted from the air in the room is based on how humid the air is. The good news is your unit is really getting quite a bit of moisture out of the air and as such, is working well to cool your room.
It is working as designed. You may want to see if you can connect a hose to a drain port (if yours has that included) to let the unit room longer without the need to drain the condensate (water) every 3 or so hours.
Hope this helps and best regards!
Jul 31, 2009 | Danby DPAC8020 Air Conditioner
The house was 79 degrees , we turned the central air on and it only cooled our house 3 degrees in 5 hours. Is that right
no this is not normal, try these steps 1) clean filters 2) clean condensor outside with a hose 3) low on freon need technician to check this and fill
Jul 07, 2009 | Heating & Cooling
Water doesnt drain out the hose when hooked up. It fills the bucket
check to make certain that the hose is not plugged.
May 06, 2009 | Heating & Cooling
It turns off
The e1 code is a demand to clean the filter. It means the unit has been running for 720 hours. It does not mean anything is broken...unless it hasn't been running for 720 hours. That would mean the "clean the filter" timer is broken! There are 2 reset methods.
1) Unplug the machine. Hold down the power button while plugging it back in and wait until it beeps (for about 5 seconds). Let go of the power button. Unplug the machine again, then plug it in and try to use it as an air conditioner.
2) Unplug the machine. Hold down the Mode button while plugging it back in. Keep the mode button pressed until it beeps (for about 3 seconds). Let go of the mode button. The machine will start. Turn it off by pressing the power button. Resume trying to use it as an air conditioner.
If neither of these work, the "clean the filter" timer is broken and needs replacing.
Jul 23, 2008 | Sharp AF-S100FX Comfort Touch Air...
Haier Air conditioner problems - e1 message
try turning it off holding buttons each individually in for 3 secs then in an hour plug back in ... the rep from Haier gave me this advice ... just waiting my hour now ... i also hear that the remote works for sure ...
Jul 15, 2008 | Sharp AF-S100FX Air Conditioner
Sharp ASF120MX
E1 fix
panel.
button.
Jun 11, 2008 | Sharp AF-S120FX Air Conditioner
Sharp CV-P09FX Air Conditioner Logo
489 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
