Question about Dishwashers
Need way of fixing pipe into fitting inside dishwasher
The internal plastic pipe that feeds into the bottom sprayer clips into the fitting but pops out when the dishwasher is on. A plumber tried gloop to hold it in place but that has all dissolved in the hot water. what is best to hold the pipe in the fitting?
  • dumyatnz May 03, 2010
    Thanks, but unfortunately the spray arm assembly is a hard plastic pipe and a worm clip wouldn't hold and there is nothing to tie it to.
    it looks like this:http://www.espares.co.uk/part/dishwasher...
  • 901 Answers
Fix a worm clip for this diameter and tighten. Also see whether you used the correct size of the hose. Otherwise tie with a strong copper wire of suitable dia.
Posted on May 03, 2010
Testimonial: "interesting idea - will try!"
  • Ambari May 03, 2010
    Fix a rubber hose of good quality in-between the two rigid pipes.
Hello there, I have a Bosch Logixx dishwasher which I purchased just over 2 years ago. My upper dishwasher tray is not fitting properly into the hose pipe holes on the inside of the back wall of the...
Hello Deepak,
You can definitely fix this yourself, but I'm not entirely sure from your description which part is "dropping off". It may be a simple fix where something needs to be clipped back into place or you may need to replace something. Please can you take a look at the images below and identify which part you are having trouble with.
Below is the back of the upper spray arm which clips on to the upper rack. It has a grey plastic cover behind which is a large white plastic washer / gasket. The washer simply slots in to the back of the spray arm and the grey cover clips in over the top.
Your description suggests the grey plastic cover and/or the white washer are dropping off. If the grey plastic cover is missing, it may have fallen into the bottom of the washer under the lower rack, in which case you should be able to find it and clip it back on. If it's missing or wont clip back on, you will need to replace the upper spray arm as the cover and washer are not available separately.
This is the water delivery tube which clips to the back wall of the washing compartment. There is a metal clip which secures the tube to the wall. The open hole and one of the spigots slot in to the two holes in the back of the upper spray arm above. The spigot used depends on which height setting the upper rack is on.
Basically, everything simply clips together. If nothing is broken, you should be able to fix this at no cost by simply clipping the offending part back into place.
Hope this helps. If you need further assistance or help locating replacement parts, please let me know what needs to be replaced. Nearly all Bosch parts are available and in stock direct from Bosch.
Regards,
BElectric
Apr 13, 2011 | Bosch 24 in. SGS69L02 Logixx Built-in...
Arms are clogged
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 04, 2010 | GE Dishwashers
LOW WASH PRESSURE ON UPPER SPRAY ARMS
Dec 04, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
The top section wont wash clean
Dec 04, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Water does not spray or circulate
Dec 02, 2010 | Asko D1776 Stainless Steel Built-in...
Machine runs but not cleaning dishes
Dec 02, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Dishwasher fills up, but doesn't spray.
Dec 02, 2010 | Dishwashers
The spinner on top of the dishwasher, that I guess shoots out the water is not spinning. I think?
Dec 01, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
AEG 50740
Some machiens front bottom plastic is a "bump" off type (push sideways clip) Some machiens have electrical elements but some (later models) have inductive heater that fit in line with thewater pipe feeding to the main top washer arm. The electrical connection to this inductive heater could be loose or the inductive heater itself could be faulty
Sep 12, 2009 | AEG 24 in. Favorit 40850 Free-standing...
Junk inside spray arms stopping them up.
Every once in a while, run it with powdered lemonade inside. It'll cut down on your lime deposits. It works. Just dump it inside. No need to put it in the resevoir
May 20, 2009 | Dishwashers
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
