Question about Garmin StreetPilot C330 GPS Receiver
Charging failure battery no longer charges, do these ever need replacement?
    President:
  • 1,851 Answers
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Posted on May 08, 2010
Why the battery of my unit is not charging? and When do i know the rechargeable battery is to be replaced?Coy
You need to replace the battery when it no longer charges or when the battery won't hold a charge and dies quickly. the charging symbol will light, as the charger is working, but in your case, the battery is not accepting or holding the charge.
Is this a hand-held DVD player?
Oct 23, 2015 | Televison & Video
Lenova tab s8 wont charge help
Hi, it maybe possibly your battery to drained flattened to the point where it cannot accept a charge from the wall charger. the best thing to do is to try and trickle charge your tablet from a low voltage/amperage connection. Either a powered on PC USB port to the charging connector on your tablet, or from a low power phone charger (5v/500ma). It has been pretty well documented that lithium batteries do not like to be drained fully & it may be that the battery in your tablet has drained so low that it cannot accept a charge from the Lenovo a/c charger.
Try a trickle charge for 8-10 hours (or longer) on your tablet & see if that gets enough charge into your battery to enable it to recognise & accept a charge from the a/c charger.
Else it replacement of charger or some hardware failure in your tablet
Oct 04, 2015 | Computers & Internet
Wont charge
Battery failure. The power cells in your laptop are a set of 6 batteries inside of a long battery pack case. Inside the case, any one of the 6 cells can die or no longer charge. A replacement is the only option.
Jan 06, 2014 | HP Computers & Internet
Battery wont charge
I've had this problem with several phones in the past. The issue is either a faulty charger, or more likely a poorly welded charge port on the phone. I've been told that this is such a common failure, that the insurance no longer covers this issue. Suggest you google the make/model of phone and include "won't charge" in the search.
I did this and was able to prove to my cell company that this was a known failure for my phone, and got them to replace it for free. I'm now on my 3rd free replacement for the same model phone.
Jan 23, 2013 | Sony Ericsson Cell Phones
D1oo Nikon enel3 lithium Battery packs stopped working
Batteries don't live forever. When handling them correct they can survive 1000 charge and discharge cycles. When taking an average of 200 pictures per charge, the battery could survive the camera shutter.
Try to use a battery till it is almost empty. The camera will give a warning when you need to replace (or charge) the battery. When you want to go on a trip or need to make a series of foot's you should take only charged batteries. When you don't use a camera, for a longer period, don't leave the battery in the camera. It could start leaking and damage the camera. But when the battery was not used for a longer period, please charge it before using it again.
This could help you to keep your batteries in better condition and let them live longer.
Dec 06, 2012 | Nikon ENEL3 Lithium Ion Battery Pack
My battery is running down quickly on acer aspire 5750-6677
This is a sure sign the battery needs to be replaced, over a period of time the charging cycle starts to break down until it lasts for minutes then failure where it will no longer except a charge.
Sep 21, 2011 | Acer Computers & Internet
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
My ups beep continuosly and then shuts off.
Classic signs of a worn out battery. Battery International has a great cross reference to find your battery: http://www.batteryinternational.com/ups-batteries.html
Oct 22, 2009 | Computers & Internet
Garmin StreetPilot C330 GPS Receiver Logo
137 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
