Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
Just lights up but computer does not detect its presence in port
  • 755 Answers
Make sure your usb port is enabled in bios and in OS.
Also try it in another computer to see if the same issue.
Posted on May 02, 2010
My Audio Isn't Working
Try another device in that port just to make sure the device is working correctly. Try the headsets in another port just to make sure it isnt a bad port.
If the device works in another port then you have a bad port even though the computer sees it.
If the device does not work in another port and a different device works in the same port then you headphones are bad.
Jul 15, 2016 | Imicro IM320 USB Headset
CSH-800 8-Port Ethernet Switch Problem When i switch the power on, only the POWER LED light up and nothing is happened, computers cant detect it
Switches arnt not detectable by the computer, a switch allows you to link multiple pcs togethers that sit on the same domain/workgroup , and also network subnet, the other lights will come one when you connect a RJ45 cable between the unit and a PC to show a port is in use.
May 10, 2011 | Cnet CSH-800 8-Port Ethernet Switch
Mother board software loading error,SPD missing
Serial presence detect (SPD) refers to a standardized way to automatically access information about a computer memory module. Earlier 72-pin SIMMs included 5 pins which provided 5 bits of parallel presence detect (PPD) data, but the 168-pin DIMM standard changed to a serial presence detect to encode much more information
Apr 20, 2010 | Gateway (12210140-90) Motherboard
How can i use a webcam with out a driver on it
Your webcam should be a "plug & Play" device. That is, connect the camera to a USB port and bootup. Your operating system will detect the camara presence and install the software for it. Windows will have a generic camera driver in its library,
Apr 14, 2010 | Intel Easy PC Camera Webcam
I need to install a webcam to my laptop but i do not have the installation cd and i dont no what model it is!!!!! How can i install it????
Apr 14, 2010 | Computers & Internet
Wd 320 gb passport works on my HP but not on my Dell inspiron ? on the hp I have no porblem - on the dell it constantly clicks and does not recognise the presence of the drive ? Thanks
You need to isolate the problem. Bypass the two computers and connect the WD hard drive into another computer (not your HP or you Dell).
Once the other computer detected the HD, then there's something wrong with the USB ports of the Dell computers. But if other computers does not detect the HD, you might need to back up the files and reformat the HD.
If you find out that you are only having a problem with the Dell computer, try enabling the USB Legacy Support of the Dell computer or try updating the USB driver.
Hope this helps and have a great day!
Aug 29, 2009 | Western Digital Elements powered by WD 320...
NetGear WG111T, hardware not recognized
If the adapter is not detected by your computer, the best way to check if the adapter is bad or not is to tr connecting the adapter to a different USB port and check if the computer will detect it and if still not detected better if you can just connect it to a different USB port and if still not detected on different computer the adapter is already bad...
Aug 25, 2009 | Computers & Internet
No lights
hello!
Is there a computer connected directly to the router? Possible that the router do not detect any physical connection on it. if none of the number light light up it means that there might be no computer directly connected to the router .
Have you tried connecting your computer to a different port? how about using a different cable? How about a different computer? if theres a computer connected to it hardwired but still no light, try to connect your computer to the other ports of the router and check if the lights will come on. if not, try a different cable and a different computer. Possible that t could be a defective port, defective cable, defective lan card or the driver of the lan card on the pc is not properly installed that's why the pc is not detected
Aug 27, 2008 | Belkin (F5D7230-4) Router (587009)
MiraScan quits when I try to load it in an image-editing software, like Photoshop. Why?
Try the program compatibility mode I think these scanner were made for 95/98 DOS machines and did not translate to EXP because of firmware differences.
Jul 01, 2007 | Acer ScanPrisa 640P Flatbed Scanner
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
158 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
