Question about GE (PSS26MSRSS) Side by Side Refrigerator
My ice maker stopped working, but the freezer was still working. Yesterday, I noticed some water at the bottom of the freezer, and everything was defrosted. The refrigerator is working fine. My model number isGSH25KGMA. what is wrong with my freezer>
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
Ge refrigerator ice maker has stopped making ice
The water valve on the back of the refrigerator is bad, one controls water for the ice maker and one controls water for door water
May 11, 2014 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Stopped making ice
Usually, the water line to the ice-maker is frozen. If you defrost the freezer, it should work again.
Aug 22, 2009 | Refrigerators
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Freezer not freezing, and leaking
If this unit has an ice maker and you noticed water leaking into the refigerator, I had a similar problem. The water turn off valve for the ice maker had a small piece of sand or grit lodged in it and stopped the valve from closing properly. So it could not turn of completely and the valve became increasingly more sloppy as the piece of sand was wedged in further. The solution was to replace the samll valve. An easy job for someone a bit handy.
If the water has frozen in the bottom of the freezer compartment the colliing port for the cold air may also be affected. Don't chip the ice out of the bottom, defrost it with pans of hot water.
Hope this helps
May 03, 2009 | Frigidaire Freezers
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
Ice maker not working
ONE OF THREE THINGS,THE INLET WATER VALVE ON THE BACK BOTTOM HAS FAILED,THE WATER SUPPLY TUBE IN FREEZER BEHIND ICEMAKER HAS FROZE,OR THE ICEMAKER ITSELF IS BAD,LET ME KNOW WHAT YOU FIND-MIKE
Jun 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Freezer Not making ice
are u getting water to the icemaker? If Not check water valve for ice maker in back of refrig.
Sep 11, 2007 | Sub-Zero 650 / O Bottom Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
50 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
