Question about Fuji FinePix J10 Digital Camera
Brand New Fujufilm Finepix z37- flash it turned on but not working?
    Guru:
  • 1,705 Answers
As its brand new, take it back to the vendor. If they can't demonstrate it working to your satisfaction request a replacement or refund. Don't muck about with it, its still under warranty and you don't want to void that.
Posted on May 02, 2010
How to return deleted images from fujufilm finepix s
Download and install Recuva in your PC. Run Recuva and select the camera. Try to recover the deleted files.
Sep 08, 2011 | FUJIFILM FinePix Z70 Z71 Digital Camera
Hi, I don not know how to charge my new camera. I bought from ebay and was provided with a uk adapter but still at a loss. No manual instructions were given.
The adapter is the charger. You can find the manual here:
FinePix Z37
The file is in PDF format. If you can't open it, download free adobe reader here:
PDF Reader
Thanks for using Fixya!
Jun 15, 2011 | Pix FUJIFILM Fine Z37 Digital Camera
How can I download Fuji finepix z37 manual for my fuji camera?
Click on the link below for the PDF manual for the camera. Once loaded up click on the save tab on the left hand side of the page >>>>>>
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/z/finepix_z35_manual_01.pdf
Regards.
Dec 23, 2010 | Cameras
My Fuji Finepix S5800 tells me my brand new batteries are flat.
It sounds like you have bad batteries. I have had rechargeables that have suddenly done the same thing. I have learned that buying really cheap ones doesn't work out. If you buy a good branded set, I think you will find that they are much better. :)
Jul 17, 2010 | Fuji Finepix S5800 Digital Camera
I have a Fujufilm Finepix S5700 digital camera. Does not power up
hold power button down and remove battery at the same time once battery is out put battery into charger, if the light shows red then it needs to be charged if it shows green allow it to stay in the charger for 3 minutes then remove the battery and install in the camera pust the power button on hold for 5 seconds, if the camera comes on your ready to go, if not then you may have damaged the battery pack and will have to replace te battery. If you have a cable that plugs into the camera try using the powrord with battery plugged in, if it does not work then your battery is bad and you will have to purchase from fuji to get the right battery pack.
Jun 13, 2010 | Fuji FinePix S5700 Digital Camera
How do i charge my fujufilm finepix z20fd?
Yes there is a special charger that you need for the battery. You can pick a charger up online for $15-$30 depending on where you buy from. Hope this helps.
Nov 13, 2009 | Fuji Finepix Z20fd Digital Camera
Fujifilm takes Disorted photos
How old are your camera and memory card? Both will eventually wear out. Digital cameras are generally good for so many shots. The same goes with the cards. I would personally try a new card and see if it helps.
Jul 25, 2009 | Fuji FinePix A340 Digital Camera
Fujufilm S700 won't power on. New batteries and are in correctly. Battery door closed properly, however, the door covering the SD is broken in half. Will this cause the camera not to power on?
Yes it will. The door activates a micro switch that cuts power to the camera when open to prevent accidental removal of the card and loss of pictures stored on the card. You can bypass this switch with either a solder "bridge" or remove the switch and use a piece of wire to bridge the pads on the board.
Apr 19, 2009 | Fuji FinePix S700 Digital Camera
When i turn on my fujufilm finepix Z2 camera it says card error on the screen and will not allow me to take photos or film.
try to take out the sd flash card in your camera, or try to format this card using your camera. you get this error coming through this card.. so it better to format or replace the card.
Oct 30, 2008 | Cameras
Fuji FinePix J10 Digital Camera Logo
69 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
