Question about Gateway FPD 1830 18.1" Flat Panel LCD Monitor
My fpd1830 monitor has been working for about 6 years. But there was a time where i left it in storage for 2 years. I put it back up on my desktop computer and it worked. I then adjusted contrast and brightness to 100 and it has been working for 5 months then I came back from 2 week vacation to find it not displaying anything on the screen. I know that its receiving power because when i plug it in the power button on the monitor turns orange and when pressed again it turns green but nothing is displayed at all on the screen when connected to computer. Not even the small message box that comes in middle of monitor that says something like "source detected" or "source not detected". So can someone please help me out? thanks
  • 11,361 Answers
This model has known problem with bad caps on the inverter board, replace all four with one cap (470uF/25V use PANASONIC FM or FC series from DIGIKEY). I fixed about 20 of this model.
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD1830/
Posted on May 03, 2010
Testimonial: "Thanks where do you think I can get the cap and what kind do you reccmnd and is there a tutorial on how to do this? Sorry I'm a begginer at this stuff"
  • Bud Martin
    Bud Martin May 04, 2010
    I would like to suggest you to get the inverter board out and take it to local repair nshop to have them remove all 4 caps and replace it with one cap (470uF 25Volt, Low ESR type, 105C, they should have this in the shop).
  • 732 Answers
Baraaosman93, I don't think software is problem. You need to sub-in a known good monitor to prove problem not in your PC!!!!!! Do you know the flashlight test to determine state of monitor switch-mode-power-supply? Because your monitor isn't any different in it's basic design and operation from that of any other brand, I will send you to do some reading at a old Hewlett-Packard (HP) monitor blog. I think it will be very helpful to you. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Yes you will need to investigate the SMPS board for bad capacitors and or thermally intermittant cold solder joints on the printed circuit board. If not into doing a DIY repair and you don't want to do any reading in my or other fixya tech's profiles, then just trade unit for new one. In any case, do additional comment after doing some research on lcd black and blank n black screen symptoms. Let others who read this know what you did to fix your problem. 12fixlouie
Posted on May 02, 2010
Dell Studio 540 will not start shows black screen with parameter error message
Not very helpful info! I would try tapping f12 on booting up which takes you into the Dell Diagnostics mode. Then come back here.
Feb 24, 2014 | Dell Studio 540 MT Pentium DualCore E5300...
NVidia 6200LE scrambling the BIOS screen
Yep.
Spanky, Alfalfa, Stymie, Buckwheat, and Darla; all down here at the He-Man Woman Haters Club,
http://en.wikipedia.org/wiki/Our_Gang
Reset your Screen Resolution
Assuming you have WinXP;
Right-click on an empty area of your desktop screen.
In the drop down list, left-click on Properties.
In the Display Properties window left-click on the Settings tab. (Top)
Screen resolution is stated in the middle. There is a Slider underneath the heading.
[ Green tipped, and capped, Down Arrow)
Drag the Slider left or right, to bring the screen resolution to the correct setting.
(Ignore if you are aware. Put your mouse cursor on the Slider.
Left-click, hold the left mouse button down. Now move your mouse left, or right, and drag the Slider )
The correct screen resolution is........................hey, come back here with THAT Spanky!...............1280 x 1024
http://support.gateway.com/s/MONITOR/7003481/700348103.shtml
To the right look at Color quality.
Should have - Highest (32 bit) in the box underneath.
If not left-click on the blue Down Arrow to the right of the box.
Left-click on Highest (32 bit) in the list.
Now go down to the bottom right of the Display Properties window, and left-click on Apply.
Finally go to the bottom left side, and click on OK.
Windows XP has the drivers.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 05, 2012 | ASUS Computers & Internet
I have a Dell Inspiron 531S, I have both two different monitor slot, does my PC support dual monitor systems?
Yes.
The area on the back of the computer, that has two ports to connect a monitor, is a Graphics Card.
It is a PCI-Express graphics card, and is plugged into a PCI-Express x16 slot on the motherboard.
(Expansion Slot)
It has a blue VGA port, white DVI port, and black S-Video port.
The area on the upper left with a blue outline around a VGA port, is a VGA port connected directly to the motherboard. It is Integrated Graphics.
You CANNOT use Integrated Graphics, and a graphics card at the same time.
It's either use the Integrated Graphics VGA port, OR use the graphics port/s on the graphics card.
BIOS will Not support using both Integrated Graphics, and a graphics card.
HOWEVER, you can use the VGA port, and the DVI port when using two monitors.
You will be only using just the graphics card.
Example of a VGA port, (Connector), and VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
Example of a DVI port, and DVI cable,
http://en.wikipedia.org/wiki/DVI_connector
1) Whatever monitor you have that has a VGA cable, plug it into the blue VGA port on the graphics card.
(There are VGA monitors {CRT} that resemble a small TV. VGA cable is usually attached.
There are also LCD flat screens that have a VGA connector, for a VGA cable, and may also have both a VGA, and a DVI connector.
To digress for a moment;
VGA is Analog. It uses an Analog video signal.
DVI is digital. It uses a Digital video signal.
A computer naturally puts out a digital video signal. This digital signal has to be converted by the computer, into analog for an analog monitor. This slows the graphics process down. This is one reason it is best to use digital )
2) Plug a monitor with a DVI cable into the white DVI port on the graphics card.
3) Turn the monitors on.
4) Turn the Inspiron 531s on.
5) When Windows has loaded, right-click on an empty area of your desktop computer screen.
Now left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
6) You are now looking at a small window that has two monitor icons in it.
Monitor 1 icon, and monitor 2 icon.
Monitor 1 icon is your Primary Display.
Monitor 2 icon will be for the Secondary Display you are adding.
Note how monitor 1 icon is sitting to the Left, and monitor icon 2 is sitting to the Right.
This is how your monitors are supposed to be arranged on your computer desk.
If the second monitor is on the Left on your computer desk, you need to move the icons around.
Move monitor 2 icon to the Left.
Left-click on the icon, hold the left mouse key down, and drag the monitor 2 icon over to the left side of monitor 1 icon. (All the way over, or it will snap back to where it was)
It may matter to you how your monitors are arranged. It may not. Once you read the following it may help you decide.
7) Left-click on monitor icon 2 if you have not already done so.
Go down to where it states, "Extend my Windows desktop onto this monitor"
8) Left-click once in the empty square, to the left of Extend my Windows desktop onto this monitor.
9) Now left-click on Apply at the bottom Right corner.
10) Finally left-click on OK at the bottom Left corner.
You should now see your desktop screen on both monitors.
When using the internet on both monitors, you have to drag the screen from the Primary monitor to the Secondary monitor.
Go to the left side of the screen. Left-click right on the edge of the blue frame. Hold the left mouse key down after you click, and drag the screen across to the left.
Doesn't work?
Go to the right side, click on the blue frame, and drag the screen to the right.
This is why it may matter how the monitors are arranged on your computer desk.
It's kind of eerie your first time dragging the screen across.
You will also find out why it is best to use two similar monitors, when using dual monitors. The pixel resolution is different for both monitors, if they are different from each other.
Regards,
joecoolvette
Just to add:
http://support.dell.com/support/edocs/systems/inspd531/en/OM/appendix.htm
Aug 15, 2011 | Dell Inspiron 531s Desktop Computer
I recently placed my computer into storage. When I took it out and set it up, the CPU seemed to be running but there was nothing on the monitor and the keyboard didn't seem to be functioning. The mouse...
unplug the power cable of the CPU
press the power button for about 5-10 secs
open the tower and reseat the memory
theres 2 white clips on each side press down the white clips until the memory pop out
check the memory if theres any dust and put it back the way it was before
push the memory back in with a small force until the 2 white clips snap in
hope this help
Sep 07, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
I bought a Gateway FPD1830 monator from a friend. What does it need other than a power cord to hook to a dell computer?
VGA or DVI cable, this cable has approx 1" x 1/2 inch blue or white ends and should connect both to the monitor and to the computer to transmit the video signal between the two.
Aug 29, 2010 | Gateway FPD 1830 18.1" Flat Panel LCD...
Have HP slimline series. Came back from a break.
Try another monitor on it to verify it is the video card that has gone bad. If it does not work with another monitor then that is the likely culprit.
May 06, 2010 | Computers & Internet
My Monitor, which had never been used but been in storage for about 1 year, has a 2 inch translucent vertical pink stripe down the left hand side. Rest of image is perfect. Any idea how to make this go...
Check the RGB settings from the monitor panel.... Plus try moving the neck of the monitor left and right a couple of times.... Sometimes, the picture tube displays illegitimate pictures with some twisted cables or so...
Jan 09, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Gateway FPD1830 Monitor Flickers then goes black
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 03, 2009 | Gateway FPD 1830 18.1" Flat Panel LCD...
Dark screen of compaq pressario desktop monitor-some time works by just shifting the monitor a bit
the light guns inside of a monitor can weaken with long use..also, the screen itself can lose it's phosphor coating as well..
your service person is correct
Mar 20, 2008 | HP Compaq Presario V2000 Notebook
Gateway FPD 1830 18.1" Flat Panel LCD Monitor Logo
282 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
