Question about Toro Lawn Mower With Toro Power Tools
How to adjust the deck on a wheel horse riding mower the 38 inch its a 1997 modle it cuts eneven for some reason
lilmikew99
  • 122 Answers
SOURCE: Toro mower won't start. No sound when I turn key.
definately connection some where i would use a volt meter and make sure where power is and make sure it is getting too where you need it, if its getting too the soliniod or not then too the starter.
Posted on May 10, 2009
  • 72 Answers
SOURCE: Mower Deck not level
there is a geared bolt at the deck suspension un lock it and rotate it will raise and lower the deck
Posted on Aug 04, 2009
harlan301
  • 205 Answers
SOURCE: I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Posted on Oct 13, 2009
  • 54 Answers
SOURCE: toro 1991 42 inch mower doesnt cut even how do i
The blades should be a simple bolt on, how ever there are no adjustments at the blade. Your adjustments are on the swing brackets that raise and lower the deck.
Posted on Apr 28, 2010
  • 16376 Answers
SOURCE: I have a Toro Z14-38
There is very little likelyhood that you will be able to get the manual that you want.
First TORO has proprietary information on their products.
Second is the fact that you are agreeing to only pay 4 dollars for something like that.
The only other thing that you can do is look in the US patents database to see what you can find.
Posted on Nov 27, 2010
My 38 inch cutter deck is rusted away, will a 42 inch fit OK ?
It depends on the brand of machine as to whether this would work or not. Some of them will interchange and work without and issues. However, most of the time this will not work due to the changes in mounting brackets and hangers.
Jan 28, 2016 | Garden
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
if you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
May 14, 2014 | Yard Machines 13AC762F000 38-Inch 344cc...
I was mowing in thick grass and my ride on mower stopped. If I try to restart I can hear and feel the motor trying but it just wont get going.
You probably hit something unseen. First check under you deck to be sure a stick or something isnt wedged in there. Check your belt and pulleys on top of the deck.
Im tempted to say check the flywheel key or adjust the valve lash.
Oct 25, 2012 | John Deere Garden
Need diagram to replace murray 42 inch cut belt
http://www.ereplacementparts.com/ type in model number of your mower ie 40560x50c All parts and diags ypu need ,Yours Henry
Aug 07, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
My riding mower has a 42" deck with 2 blades. Left side cust much lower than right side. It looks like two different cuts. How can I fix this?
adjust the cutter bed so that it cuts the same hight
look at the mower bed and feel how high it is on both sides if diferent adjust it so its the same hight,
Jun 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Poulan 38" 15.5 hp lawn mower cuts off when blades engaged.
you have a bad blad saftey swich that all it is replace that and youll be good to go
Oct 01, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a mtd 13.5 horse 38 inch cut 6 speed its around a 2007 or a 2008 i need to se how all the belts go on the mower deck and drive
Most mower decks have the diagram on them, if not go to MTD.com and put your model number to see the diagram.
May 02, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Launch on take off
I have the same problem sometimes, but it is only when I let the brake / clutch out fast. When you go to let the clutch off, and you are in gear. Try easing off on throttle, you can increase the throttle after the clutch is out. THis should help with you sore neck. Another thing you may want to try is adjusting the throttle calbe. It should show or tell you in the manual how to do this,
Apr 24, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Toro Lawn Mower With Toro Power Tools Logo
289 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
