Question about Acer Aspire 6920 Notebook PC
BATTERY PROBLEMS WONT CHARGE NO HIGHER AND IT A NEW BATTERY
I GOT AN ACER ASPIRE 6920 AND THE BATTERY WONT CHARGE ONLY GOT 23% LEFT AND IT SAY BATTERY OK AND CHARGEING BUT WONT GO HIGHER AND THIS IS A NEW BATTERY
  • 186 Answers
Cable to charge maybe defective;
Posted on May 02, 2010
My acer 6920 keeps saying no battery is detected
check that the replacement battery casing is not warped by an overheated previous battery stack. Same issue with this laptop.
Apr 05, 2013 | Acer Aspire 6920 Notebook PC
Acer aspire 6920 11.1 v battery work but 14.8 v wont charge why is this
Check model numbers, I had this problem with apple, to of the same laptops two differnt batteries
Apr 03, 2017 | Acer Aspire 6920 Notebook PC
BATTERY DOESN'T CHARGE ON MY ACER ASPIRE ONE MOD#KAV60
Sounds like the battery might be bad. Try another battery in the laptop and see if it charges. If it does then you know the other battery is bad.
If you try another known working battery and it still wont charge, then try another AC Adapter. If you still cant get the laptop battery to charge then at that point the motherboard is bad because you will have tried another working batter and another working ac adapter.
May 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Battery wil not charge. Ordered new battery, still will not charge, brought new power cord and still will not charge.
Internal issue, if it is possible check to make sure there is power coming out of the prones where the battery sticks in, if you have a tester you will be able to test if there is power going to the battery.
Dec 31, 2010 | Acer Aspire 6920 Notebook PC
Acer aspire 6920 battery problem.. laptop only recognizes the battery and will not charge now... and only lasts a few minutes
1.Remove ,the battery and adopter from your machine.
2.And then press the power button form 36 Second.
3.And then refix your battery and adopter to your machine.
4.boot your system
1.first Instal the E-power management to your machine.(Didn't had means kindly download the application from our website www.acer.co.in.
2.fully charge your battery till 100% without any interption
3.now you work with your laptop untll it would be the 0%.
4.Kindly repeat the steps four times.
5.After that you Defently feel,your battery backup will increase.
Nov 16, 2010 | Acer Aspire 6920 Notebook PC
Problems with new laptop battery for my Acer 6920G.
You can't force the battery with a higher charge to work without damaging the computer. If the battery is a direct replacement it should work. If your original charger is not capable of charging the battery you can consider a charger replacement but I suspect the original charger you where using was bad to begin with if that is the case. You can try locating a replacement charger but you need to make sure it is rated for computer so you don't damage the power system.
Jun 20, 2010 | Acer Aspire 6920 Notebook PC
Acer aspire 6920 just went off yesterday abruptly. no power with or without the battery. no power when just using the power cord. I tried removing the battery and ressetting the power button ( no luck)....
Take the battery out and short the pins. If this doesnot work than seems your power adapter is problem. It is not charging the battery. Check if your power adapter is OK. If it is ok than looks like the power jack pin is open. Take it to repair center to have the Jacks fixed
May 12, 2010 | Acer Aspire 6920-6621 Notebook
My lap top wont turn on i have a blankj screen the
Please try these. After on your pwoer botton wait 2 minites and the press FN+F6.
Let me know what happening.
Thanks.
Jan 30, 2010 | Acer Aspire 6920 Notebook PC
Got new battery for acer aspire 6920. not charging
You ordered the wrong battery, theres two types, your original would have been 11.1v if you check the new one it will be 14.8v. They are not compatable.
Nov 19, 2009 | Acer Aspire 6920 Notebook PC
No power wont charge battery power cord works though
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 28, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 6920 Notebook PC Logo
550 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
