Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Trolling motor stops when being used.
When using my Pro Series 4300 (bought in 2003), it will stop in all speeds when trying to use it. It will run for a bit, then stop, run for a bit then stop. It doesn't matter if it is on continuous or not. Last year it was only doing it on the High speed of 5, this year it is cutting in and out when using it in all speeds. The duration of time does not seem to be an issue when its being used. It could start doing it 5 minutes after the 1st use of the day, or an hour later, but once it starts it doesn't stop. All the connections in the foot pedal are tight and clean. It does it bad enough that I can't use it on speed 5 at all. May run for 15 seconds on 5, then it quits. I don't know if it is the windings in the motor getting hot and cutting out or not. Any guidance would be appreciated, Thanks
Rich Craven
  • 323 Answers
SOURCE: Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
Posted on May 23, 2009
SOURCE: Foot pedal on Motorguide is out of time with steering...
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
Posted on Jul 24, 2009
wireguy212
  • 1627 Answers
SOURCE: I don't have any slow trolling speeds. Only fast
To hook up to 24 volts you need to join a positive cable from one battery to the source[motor or controller] and the the negative cable goes to the positive of the next of the next battery,then the negative [of battery #2] goes to ground,same for all 24 volt systems.If the slower speeds don't work then the rheostat in the accelerator handle could be at fault,but getting the 24 volts sorted out may fix everything.
Posted on Jul 22, 2010
SOURCE: Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Posted on Sep 16, 2011
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
I don't have any slow trolling speeds. Only fast speeds on my Pro Series 6700 trolling motor. Any ideas? Also, it is a 24 volt system. How do I properly hook up the batteries. The two batteries are...
Jul 22, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Hot plug connector
if everthing else is hooked up properly and the battery connections are tight i would suspect a loose connection in either the plug or the receptacle. anytime an electrical connection heats up it usually means there is a loose connection or too many amps running through it than what its designed for. remember trolling motors should not be run out of the water for more than 30 seconds as they use the water to cool the output shaft at the prop. good trolling.
May 30, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I have a motor guide 4300 pro series trolling motor. recently I have developed a problem with the control switch turning the motor off and on.I can turn it off and on by the side 12 and 24 volt toggle even...
I'm not sure my earlier post went through..Again, Mine is doing the same thing. I noticed a piece of rubber on the floor next to the foot control. I think this piece of rubber was on top of the switch and allowed it to make better contact with the gray lever. I'm going to tear into mine this week. I'll post my results here.
David
Oct 18, 2009 | MotorGuide Electrical Supplies
On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Wring for trolling motor
just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
Jan 18, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Minn kota turbo 35 27lb thrush trolling motor
I have a minn kota turbo 35 27lb thrush trolling motor after 3 hours of running it the motor dies
Mar 01, 2008 | Minn Kota GPS
I'm using a toshiba 4300 satellite pro 4300 series laptop, i don't know how to dim the screen. i've tried pressing Fn and various F keys to no avail. Please don't reply in computer language because i'
Hi. According to the user manual, the Fn + Esc (key)displays the screen brightness pop-up window which are: super bright; bright and semi bright. You may want to check out Toshiba 32-bit Online User's Guide for Satellite Pro 4300 Series (5790)at http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=107128&moid=1073769765&BV_SessionID=@@@@0579949615.1140817607@@@@&BV_EngineID=cccfaddhdidhgdecgfkceghdgngdgmm.0&ct=DL. Hope this works out ok for you. Regards.
Apr 09, 2007 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
293 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
