Question about DeLonghi PAC C120 Portable Air Conditioner
New unit installed when turned on "FT" light displays
Just installed a brand new PAC C120 following all of the instructions in the installation guide. there are no kinks in exhaust hose. When I turn on the unit the FT full tank light comes on and the unit won't start. There is no water in the tank, since the unit has never operated yet.
Thank you.
  • 674 Answers
Remove the tank if it is removable and see if you can determine how it is sensing the tank level. Maybe it's a float switch that is stuck or maybe it works by the weight of the tank. Either way your problem will be with whatever senses the tank level.
Posted on May 02, 2010
Sorry I do not speak English well. C120 pac my team. PF mark on the screen and turn on all lights. not working I have to do Thanks for your time
This unit stopped working and displayed the PF code for Probe Failure. I fixed it by removing 6 screws for the panal and 4 screws for the back panal and removing the 5 screws and 1 screw holding the ground wire off the silver box with the circuit board in it then I un plugged the little plug for the 2 probes with the black wires in it and replugged it in and wiggled it several times with the unit pluged in (be carefull not to get shocked I recomend someone with electrical experiance do this for you) the plug must get corroded but this fixed my unit.
Good luck.
Sep 13, 2011 | DeLonghi PAC C120 Portable Air Conditioner
How to change or clean the filter and where to download a manual
DeLonghi has the manuals for their portable air conditioners here: http://delonghiusa.com/support/product_manuals/5#table-jump . The direct link to the PAC C120 manual is http://delonghiusa.com/support/sites/default/files/product_manuals/m-PAC+C120.pdf .
Before cleaning, turn off the air conditioner. To clean the filter, pull it straight up from behind the top of the air intake (on the back of the PAC C120). Vacuum off the filter. If it is very dirty, immerse it in warm water and rinse several times. (The water should not above 40 degrees Celsius (104 degrees F)) several times. Then allow the filter to air dry. Slide the filter back into the air conditioner and turn the unit back on.
I hope this helps.
Jul 17, 2011 | DeLonghi PAC C120 Portable Air Conditioner
Brand new delonghi PAC C120e, I got everything installed easily with the unit rite next to the window, I have it turned all the way down and it still does not cool my small room at night. It seems to blow...
Since the unit is new and under warranty and hopefully you have registered it with Delonghi. Your best bet, is to contact their Customer Support Rep 800-322-3848. Doing it this way has you totally covered.
Jul 12, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
I lost my installation cd for my x2470 printer. I do not have money,is there a way to install it witout a cd
    • Step 1 Open your web browser and go to Lexmark's "Drivers and Downloads" page (see Resources section below). Locate the search box labeled "Search by Model" and enter X2470. Press return. Select your operating system from the pop-up menu. Wait for the download page to load, then click the "Download Now" button. Save the installer file to an easily accessible location.
    • Step 2 Rotate the printer so that the rear section is in view. Connect the power cord to the power cord connector located on the right. Plug the remaining end of the power cord into an electrical wall socket. Connect one end of the USB cable into the USB port located on the left. Rotate the printer back into place.
  • Step 3 Turn on your printer. Extend the paper guides and insert paper into the tray. Readjust the paper guides so that they are flush with the paper.
  • Step 4 Lift the scanner unit and wait for the print cartridge holder to move into view. Push down on the light blue lever to raise the cartridge holder lid. Install the ink cartridge into the print cartridge holder. Close the cartridge holder lid and lower the scanner unit.
  • Step 5 Connect the remaining end of the USB cable into any available USB port on your computer. If any "Add New Hardware" screens appear on your computer, click "Cancel."
  • Step 6 Open the previously saved installer file and follow the onscreen instructions.
  • Step 7 Locate the button on your Lexmark X2470 that looks like an open scanner pointing to a computer monitor. Press and hold this button for three seconds. Follow the instructions that appear on your computer. Once this is complete, your printer is ready for use.
May 23, 2011 | Lexmark X2470 All-In-One InkJet Printer
Compressor not turning on - but unit turns on and fan works - even when temp turned all the way down.
all the way down is as warm as the refrigrator can get. Sounds like start components are the problem.
Apr 17, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
Xerox c20 doesn't print. the paper runs through & comes out blan
hello sir; you said this one is brand new, did you follow the installation instruction, no matter what, just di it again,
1, press "menu" ,
2, press up/down arrow keys until"new drum" display
3, press "mode/enter"
4, when you see"new drum unit?" press "1" to select "yes"
5, turn power off and on .
Dec 28, 2008 | Xerox CopyCentre C20 Black and White...
C120 Installation Problem
call the manufacturer immediately for ink replacement.
Jan 07, 2008 | Epson Stylus C120 Color Printer InkJet
Hooking up a Pac Ipod Cable
the pac cable plugs in to the back of the stereo you cant get it wrong its a big round plug and the place you plug it in at is right next to the red and white rca plugs at the bottom of the big chunk of alluminum now if you need any more like getting the player out of the dash post a new comment listing the type of vehicle and instalation ex..dash install kit usualy scouch
Jul 19, 2007 | Alpine CDA-9827 CD Player
DeLonghi PAC C120 Portable Air Conditioner Logo
278 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
