Question about Chi Mei Corporation CMV-946D/A Monitor
The lcd back light not turning on just can see some of the shadow running under the screen.
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 03, 2010
Pkg-rse2 screen is dim and can't see it
LCD is not affected by cold. This sounds like it is the backlight or the inverter that runs the back light. The back light causes the lcd to be able to be seen.
Mar 24, 2014 | Alpine PKG-RSE2 Car DVD Player
SCREEN FOR MY NOTEBOOK IS NOT WORKING BUT THE PROCESSOR IS RUNNING
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it. Usually you can find cheaper replacements on Ebay.
Jan 15, 2011 | Fujitsu Siemens LifeBook S6120 Notebook
Shadow area on LCD screen.
one or more of the led back light lights has probably gone out and there is no way to fix it except to get a new backlight
Jan 20, 2010 | Emerson EWL3706 37 in. LCD Television
Toshiba 37WLT66 LCD TV screen has a grey shadow verticaly down left side.
I have a Toshiba LCD TV .a very light shadow on the screen just to the right
Dec 14, 2009 | Toshiba 37WLT66 37 in. LCD Television
Symphonic 32'' lcd tv has shadow on right side of screen
The "shadow" indicates a failure either of the LCD controller, LCD connector, or in the worst case, the LCD itself. A loose connection between the LCD and the LCD controller can result in abnormal displays. Try tapping the back of the TV and check if the shadow can be affected. If it is affected, try cleaning the connector terminals with a soft-bristle brush and alcohol or lacquer thinner. If not, have it checked by a qualified technician to carry out the proper tests to determine which of the LCD controller or LCD the problem lies.
Dec 06, 2009 | Televison & Video
Shadow on lcd tv screen
A shadow of any kind showing up on a LCD TV is going to be a defective LCD panel. If not under warranty your replacement cost for the panel (if available) will far exceed replacing the TV with a new one.
Jul 23, 2009 | Westinghouse Televison & Video
Blue shadow
No. I would suspect it being a Optical Block issue. I is not a pretty repair not to mention the cost factor. If you could get in touch with Hitachi Customer Service they could lead you to s service facility that could comfirm what I think.
Jun 22, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
DARK SHADOW EFFECT UPPER CORNERS OF SCREEN
I would check for dust particles before I attempted any type of repair on the unit.
Dust particles will appear as dark spots that are larger than the size of an individual pixel. It must first be determined if the particle(s) are on the LCD panels or the screen.
May 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Dark shadow like mark on screen
The drak Shadow mark I see on my Screen looks like the black soot like marks you see at the end of a flourescent tube. I think it is the back light.
Dec 18, 2008 | Philips 32PF5531D 32 in. LCD Television
T-mobile Shadow
The connection in the LCD->Keyboard cable is broken.
Need to replace under warranty.
Jun 22, 2008 | HTC Shadow Smartphone
Chi Mei Corporation CMV-946D/A  Monitor Logo
211 people viewed this question
Top Chi Mei Corporation Computers & Internet Experts
Jax Planet
Jax Planet
Steven's...
Steven's...
Are you a Chi Mei Corporation Computer and Internet Expert? Answer questions, earn points and help others
