Question about Canon PIXMA MX310 All-In-One Printer
Alarm says paper jam,cant find any paper jam,
Printer will not reset
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 02, 2010
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
Jan 27, 2016 | Epson PRINTER,ARTISAN 730
Reset canon printer MP500
Call canon tech support for any of issue in printer you can them directly here is the number (877-690-9305)
Jul 26, 2014 | Canon Pixma MP500 All-In-One InkJet...
An error appear in lcd screen of canon Mp550 is 5b00 please send to me an urgent soluation
If you encounter "Error Code 5B00" it means that the Printer Counter Protection is Full and it required a reset and Ink absorber replacement, if you want your printer to work again. There are two ways to reset the Canon MP printer, One is by using a Software tool and the other is manually resetting the EEPROM of the printer. Below is the step by step procedure on how to reset your Canon printer.
1. Using MPtool Software to reset Canon MP Printer
Turn of printer then run mptool software this software automatically detect the printer.
Click reset main and reset platen button in the waste ink counter section.
If you want to reset the cartridge ink level, click reset black and reset color in the ink counter section.
2. Manual Reset of the printer
Turn off the Printers.
Press and Hold the button Resume/Cancel then press POWER button.
Release the Resume/Cancel button while keeping POWER button on press.
Press Resume/Cancel 2 times and then release all the buttons.
When the indicator recorded GREEN - click Resume/Cancel 4 times!
Turn off and On the Canon Pixma MP Printers. And your done.
Feb 21, 2011 | Canon PIXMA MP520 InkJet Printer
En la pantalla de mi impresora aparece error 5B00 digame q puedo hacer?
Feb 02, 2011 | Canon MP490 InkJet Printer
A piece of paper jammed up. I took the paper out but the alarm keeps on saying "Carriage jammed"
Hi there !
Check again your printer and maybe there is still paper jammed inside. Turn off your printer. Open the door cartridge and remove the cartridge. Check for paper jammed. After that return the cartridge and turn on your printer. Sometimes there is paper jammed inside that printer. Just press the power off and turn it on to roll over any paper jammed inside. Turning off on your printer also make your computer refresh the memory of your printer paper jammed.
To make hard reset of your printer. Turn off your printer and remove the power cable to your printer, leave it for five minutes and connect the plug and turn it on again. That will refresh the memory of your printer.
I hope it helps you.
Jan 25, 2011 | HP Officejet 7310 All-In-One Printer
I have an error code 5B00 on my Canon MP830 printer. Can you help?
If you encounter "Error Code 5B00" it means that the Printer Counter Protection is Full and it required a reset and Ink wastepad replacement, if you want your printer to work again. There are two ways to reset the Canon MP830 printer, One is by using a Software tool and the other is manually resetting the EEPROM of the printer. Below is the step by step procedure on how to reset your Canon printer.
1. Using Mptool Software to reset Canon MP830 Printer
Jan 24, 2011 | Canon PIXMA MP830 All-In-One InkJet...
ERREUR 5B00
Jan 17, 2011 | Canon PIXMA MX310 All-In-One Printer
Paper jam
You need to open and close the front cover to reset the printer and clear the jam error message. See here and search "paper jam".
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 27, 2009 | Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
222 people viewed this question
old marine
old marine
