Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
1 HP electric motor hums but not turning.
1 HP A.O. Smith 56J inground pool motor was running fine. Is 1 year old, turned it off last night- -went to turn it on today and motor hums but doesnt spin. I removed back cover and can turn motor by hand freely. Also removed motor from front connection and can turn impeller freely.
(can see whole shaft spinning from impeller to back electrical contact point- - -shaft not broken) Its all wired properly, as stated the motor has been running fine since purchased new last June 2009. Any ideas?
Thanks.
  • 198 Answers
Check for a re-set button somewhere on the motor housing.
Posted on May 04, 2010
  • ewickha1 Sep 03, 2010
    did you figure out the problem? i have the same A/O smith motor and the same problem as you do.
  • lasalinagary Aug 16, 2017
    capacitor bad or centrifugal switch not making
Opener chain not moving and motor humming
It is likely the motor start capacitor has failed, especially if it gets going when the motor is turned manually.
Oct 05, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
I have a hayward pump model SP2610X15 that will only hum when turned on. I replaced the capacitor, it did not help. What else could be the problem?
DIRTY START switch or the motor is locked up, breaker off ! remove motor from tank body and see if the motor will turn over if it does could be the switch or the motor is shorted witch there is no fix but a new or rebuilt motor. search your area for your local pool pump motor repair guy with free testing..
Jay the pool pump motor repair guy longwood Fl
Apr 02, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
The pool timer goes on, the hayward 2 HP pool pump turns on and then causes the circut breaker to pop. After two, three resets, it starts to work. This problem started a week agao. The pump is 9 years old.
could have a bad run capacitor or a start capacitor . search your area for your local pool pump motor repair guy with free testing, 9 years old that motor needs to be rebuilt.. i charge 85.00 to rebuild a 2hpincludes a free shaft seal.. remember to prime the pump with water after a repair !! best of luck .. oh breakers become week after amount of time time .. and ask the repair guy if this is the right size pump for you pool.. 9 out of 10 times its way too big !.. jay longwood florida
Sep 08, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
When the motor/pump is powered on sometimes it makes a humming noise ans after a few seconds it sets the breakers off. If I manually attempt this a couple of times the pump starts up OK. This does not...
Your motor is covered under a 1 year manufacturers warranty. The issue you describe can be one of a couple problems all of which will lead to permanent motor failure if not corrected. I'd suggest you go back to the place of purchase or contact AOSmith for a warranty center near you.
You can find the warranty center online at:
http://www.aosmithmotors.com/AOSECatalog/ServiceshopLocator/ServiceShopLocator.aspx
John
Jun 28, 2011 | Hayward 2hp Pool Pump Motor A O Smith...
I replaced my motor 1 yr ago and all worked fine...now the low speed works but the high speed only makes a humming noise.
SOUNDS LIKE A DIRTY START SWITCH OR CAPICITOR. THES MOTORS ARE NO JOKE AS I'M SURE YOU ARE STILL FEELING THE PAIN OF THE PURCHASE PRICE.. LOOK FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING ,USE YOU ZIP CODE ..
I WOULD HAVE THIS TYPE OF MOTOR SERVICED EVRY YEAR ! 1ST TIME ABOUT 80$ NEXT YEAR 40$ WHAT I CHARGE..
DON'T TAKE THE CHANCE HAVE A PRO LOOK AT IT, THERE TOO EASY TO SCREW UP .$$$... IF YOU UN-HOOK THE WIRES TAKE PICTURES OR WRITE DOWN WERE EACH ONE GOES !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!BEST OF LUCK..
HOPE I WAS OF SOME HELP, VOTE IF'N I WAS
Aug 07, 2010 | AO Smith 1 hp 3450/1725rpm 56J Frame 230...
I have Hayward Centurian SE 2 hp pool motor pump,around 15 years old. Just the other day it started making a loud whining noise. Is there a quick fix for this?
if its whining but still spinning, the bearings are done. If it just makes a loud noise, the capacitor could be bad or the bearings have seized.
Jul 04, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
The pump only hums when plugged in. Any suggestions?
It sounds like the impellor is locked. Take this part off and then see if the pump is turning but before you do, some of them have a big screw driver slot in the shaft. If it does, turn it to see if you can free the impellor. I have done this many times and they will continue to work for years after. They just get stuck from rust, etc. and also being frozen a little. Hope this helps.
Jul 06, 2009 | Hayward 1.5hp Pool Pump Motor Motor A O...
High Ringing Noise
Sounds like it just needs lubricating. It's probably dry seals rubbing against the stainless shaft.
Bad bearings usually make grinding noises. Replacing bearings can be a DIY job, but not a teriffically simple one.
Apr 21, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
2,482 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
