Question about Toshiba 65HM167 65" Projection Television
What is a pc broad cause my tv won't come on and i have heard it need a pc broad
  • 4 Answers
If you are seeing the yellow light blinking 3 times repeated over and over the boot data is corrupted. Download the firmware update(link below)from Toshiba and unzipwhat is a pc broad cause my tv won't come on and i - 2_bing.gif the files and folders,copy the unzipped files & folders to a SD card (like a camera uses,I used a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in2_bing.gif the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
www.tacp.toshiba.com/customersupport/model_firmware.asp?model=65hm167
Posted on May 06, 2010
    Problem Solver:
  • 17 Answers
Unplug the set read the manual and remove the lamp, do not touch any part of the glass blub just handle it by the plastic, look closely at the lamp it should look messed up, if so that is your problem not the P.C. board, which is like a mother board in your computer, and not cheap., neither is the lamp but not as bad.
Posted on May 04, 2010
Heard a pop, tv went off, and it won't power up
Power supply in most cases and a lot of the time the part is under a heat sink where you cannot see it.
You might have more help if you posted the question again with the exact brand and model number.......
Dec 12, 2012 | Televison & Video
I have an Acer 5520, using Empowerment Technology, running on windows vista, it can connect to my sky broadband, but then the broad won't connect on to the internet.
the obvious is restart the laptop, but alternatively what you can do is try and find an updated driver. to find out what driver you currently have and who makes it right click my computer and go to manage, then click device manager.
the driver your looking for should be under networking it should have something like "WLAN" the other should have "LAN" once you've found out who makes it go to their website download the latest driver and install test again.
Feb 23, 2012 | Acer TravelMate 5520 Notebook
The ice machine it beeping 3 time. I reset the little white button on the pc broad. It run for a while and the beeping sound come back. I know if I hit on the F/S with my crew driver it turn to diffrent...
sounds like you may have more than one issue. Tapping the float switch indicates that it is sticking. This will keep the water coming in and the unit will not go into it's freeze mode. Go to the Hoshizaki web site for how to remove and clean. It's really not that hard. If you can't find it, I'll walk you thru.
With the machine turned off, is there still water running? IF so, the water valve is also stuck in the open position and letting water in. This could cause it to have long freeze cycles and possibly freeze up.
Start there and let me know if you need any more help.
http://www.hoshizakiamerica.com/techsupport/tech.asp?
Feb 27, 2010 | Freezers
Broad panel of strips (Vertical) down approx one third of tv
It can either be the LCD driver board or the worst case, LCD panel.
Nov 17, 2009 | Televison & Video
I keep getting error reports on my pc despite running anti virus. What can I do?
"Error reports" is a very broad category of problem. Usually denotes software conflicts. Viruses can cause some such problems, but so can a host of other things, including incompatible programs or failing hardware. You'll need to post more details about the problems to get enable us to help.
Sep 15, 2009 | Acer Aspire 3000 Notebook
Vertical lines problem
On your blue tube there is a crt broad that may have a bad capacitor 4.7uf 250 volts most likely it can be leaky not able to hold correct charge also it might have video ic on same broard breaking down, this will cause your problem unplug crt broad from bottom neck of tube turn set on see if problem goes away if so then it means you have problem with crt broad or it could be your tube.Hope this helps you out!
Jan 18, 2008 | JVC HD-52Z575 52" Rear Projection...
Rca Goes Green
replace video ic on Green CRT broad,also look for leaky capacitor on same broad replace it also, If this does not fix it then you have a bad green tube!
Nov 29, 2007 | RCA HD52W59 HDTV Projection Television
Toshiba 65HM167 65" Projection Television Logo
257 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
