Question about Buffalo Technology DriveStation Combo 4 1 TB USB 20 Hard Drive
Disconnecting unexpectedly! My external buffalo is disconnecting itself unexpectedly during use. At first, it was happening with the firewire 400. I thought there was a problem with the firewire cable or the firewire port on the hard-drive, so I switched to USB, which worked fine for a while. But now even with USB, after an hour or so of work, the Buffalo will disconnect itself for no apparent reason. Sometimes, it is even less than an hour. It is very frustrating as I use it to edit with and sometimes, it cuts off with no warning, causing me to lose my work. Inactivity seems to affect it more than when it is fully in use but I have no energy-saving preferences turned on that could lead to the drive going to sleep. Could it be the power cord or is it problem with the drive itself?
    New Friend:
    Problem Solver:
  • 6 Answers
Hello! My recommendation would be to check if the Drive is over heating. Excessive heat could cause the disconnection either for drive protection or because solder points lose strenght. Turn it on, use it a while, right when it disconnects check if its hot. Or try to dissipate better the heat and see if it lasts longer
Posted on Mar 22, 2017
  • 88 Answers
SOURCE: buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to
Posted on Jan 11, 2009
  • 696 Answers
SOURCE: buffalo drivestation 500 gb wont start
Certainly we can help,
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Posted on Jul 09, 2009
  • 696 Answers
SOURCE: My DEll PC runnig XP SP3 cannot
Yes the drive is compatible with XP. I have seen a slightly higher than normal # of problems with their 1TB models so this may just be a batch problem. My suggestion if there's nothing crucial on the drive is to return it an purchase a different brand.
If it's not returnable you'll have to settle for asking Buffalo for a replacement. If there's crucial data on it you will need the help of a recovery pro. In that case, comment back with your Country, State and City and I will point you to a nearby Recovery facility.
Hope this helps FixYa,
Posted on Jul 18, 2009
  • 3153 Answers
SOURCE: remove all programs and encryptsion software from buffalo minista
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
BUT the section that may be of interest to you is just after step 5.
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
SOURCE: Computer not accessing Buffalo HD
my Buffalo external hard disc can be detected by laptop, but my access is denied. When i click on the hard disc icon, it popped out a message box prompting me to reformat my hard disc. Is there any other way to retrieve my files before reformat or
is there any other way to recover my files after reformat?
Is there any other way to troubleshoot my hard disc other than reformatting it?
Please help me, I am desperate to recover all my files because they are too important/precious to lose it.
Posted on Jan 31, 2010
I forgot my password of buffalo HD-PX320U2 and hint. please help me out. i do not want to format my disk.thanks
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
Hope this helps
Jul 17, 2011 | BUFFALO hop 320GB MINISTATION METRO(...
My buffalo combo 4 2 TB wont show up on my xbox 360. I already have it formated FAT32
The Xbox 360 can only recognize drives up to 16GB as noted on their website, I myself have tried a 32GB flash drive to test the limitations and it was not recognized. At this time it seems as though microsoft is limiting their external storage to 16GB.
Apr 02, 2011 | Buffalo Technology Buffalo DriveStation...
I was printing pictures and watching video from my external Buffalo hard drive last night, now this morning it can't read anything from the drive and says it is not formatted? I have plugged it into...
Hello Diane,
Your problem is a common one and thankfully the solution is equally common. You're drive was either turned off, disconnected from or the computer was rebooted unexpectedly while the drive was active. If you leave your computer on overnight this may have happened when the computer went to sleep.
Regardless of the reason the messages you're recieving simply mean the formatting on the drive that tells windows where everything is on the drive is really messed up.
You can either send you drive to a pro for recovery or you can try it the D-I-Y Method. Typlical pro rates for this type of thing are $200-$400. D-I-Y methods are typically $40-$100 with slightly lower success and you will need to have enough room free on your drive or you will need to have a second drive to copy the retireved files to during the process as it is not safe to recover them directly to the same drive.
Your files can be retrieved with one of a couple inexpensive programs. Both provide free trials that will scan the drive and display any files that can be retireved. If the cheaper one(PC Tools) works buy it and then run the retrieval part of the program. If it doesn't then try the pricier one(Disk Doctors). I have articles about both I will point you to on my employers website. If you have any troubles reply back here and I will be happy to assist you further.
My review of PC Tools recovery software
My article on formatted drives
Please remember in the future to never rely on a single copy of any file or a single hard drive, always keep you data on two seperate drive or more to ensure better chances of keeping your data safe.
Sep 21, 2010 | Buffalo Technology Computers & Internet
I purchased a JVC BR-DV600U DV deck to use with my Mac computer for video editing. When I plugged the Firewire cord from the deck into the computer, problems began to happen. Two of my three external...
There exist a number of methods for dealing with FireWire device interference, a few of which are explored here. Switching Ports The first procedure you should try when experiencing a problem that you believe to be caused by device interference is to simply reconfigure the arrangement in which your FireWire peripherals are connected. Try switching each device to a different port, or temporarily disconnecting one or more of the devices. In particular, if you are a PowerMac G5 owner, trying switching devices from the front to back ports or vice versa. Adding an external hub In some cases, it appears that FireWire devices are not drawing enough power from the computer. This can cause a sundry of strange issues, including apparent conflicts between devices and unexpected power-offs during device operation. In these instances, adding an externally powered FireWire hub can clear things up. One of the reasons an "under-powered" situation can occur is that different Mac models have varying power capacities available through their FireWire ports. PowerBooks and iBooks have the least, generating around 7 watts. The iMac G5 also generates a relatively low amount of FireWire power, sharing 8 watts between its two FireWire 400 ports. The Power Mac G5 shares 15 watts between its one FireWire 800 port and two FireWire 400 ports. Place devices on different FireWire busses/Isolate the iSight Similar to the above procedure, adding another FireWire bridge -- via an extra PCI-based FireWire adapter or another means -- can eliminate conflicts from devices that reside on the same bridge. Power cycling the system Simply cycling the power on your system may be enough to temporarily eliminate a few FireWire conflict issues. Shut down your Mac, and disconnect all FireWire devices as well as the computer's power cord. Leave the system off for about 10 minutes, then plug it back in. First turn your Mac back on, then re-attach the FireWire devices one at a time and check for the conflict to resurface. Disconnect specific FireWire devices (especially iSight) to check for conflicts As noted above, the most common cause of interference is Apple's own iSight. In case after case, simply disconnecting this single device has eliminated problems with other FireWire devices. Other devices often implicated in FireWire conflicts include video-related devices; cameras, the EyeTV, video decks, etc.
Disconnecting the iSight has proved particularly successful for an issue where the iPod disappears from the Desktop and from the iTunes playlist, while the iPod status screen cycles from the Apple logo to a "Do not Disconnect" message over and over. The exact reasons why the iSight causes more than its fair share conflicts with other FireWire devices are many, and sometimes unclear. One potential source of conflict, however, could be the unit's high bandwidth usage. The iSight captures video at a 640 x 480 pixel resolution, at 30 frames per second in millions of colors. Such throughput uses a significant chunk of the standard FireWire port's 400 Mbps bandwidth. As such, when other devices are connected, the bandwidth requirements for satisfactory performance may not be met. Try disconnecting all FireWire devices, then adding them back one by one and repeating the originally failed operation to check for conflicts. Apply the latest updates Make sure that your FireWire drives are using the latest firmware (check the manufacturers' Web site) and the most recent iPod update has also been applied. Of higher importance, if you have an iSight, is the iSight 1.0.2 updater. In a large number of cases it has resolved conflicts caused by the camera. Re-apply the most recent Mac OS X combo updater In some cases, re-applying the most recent combo updater can resurrect seemingly defunct FireWire ports and allow devices -- drives included -- to be recognized again. The most recent combo updater is available from Apple's download page. Clear caches Try using a tool like Tiger Cache Cleaner or Cocktail to remove potentially corrupt system caches. Restart, then check if your FireWire devices are recognized.
Feb 05, 2010 | JVC BR-DV600U Mini DV VCR
External hard drive emits noise and disconnects within 60 seconds
please try changing the hard disk compartment and thanks for your question
May 20, 2009 | Computers & Internet
Windows XP stopped recongizing eGo external Hard Drive
check for updated drivers
or unistall previous driver & install updated one
May 18, 2008 | Iomega Portable USB 2.0 & FireWire 400...
Installing Firewire 400 on a Western Digital 500gb external My Book Pro
Don't connect the USB and firewire at the same time, use one or the other. In general for USB, for the very first connection, it is better to have the computer fully booted, and the MyBook spun up, before connecting the USB cable. After that, you can boot the computer with or without the MyBook connected or turned on. For the firewire connection, check your manual for the correct order of connection and power on.
USB and firewire 400 are roughly comparable. USB is theoretically a little faster, but you will see little difference. There are other factors that can affect your actual performance, so your best answer is to try a test yourself. Time a copy of a very large file, and a copy of a folder with a very large number of files.
Dec 03, 2007 | Western Digital MyBook Pro WDG1T5000 500...
LaCie FireWire drive
I would seek out the latest drivers for the card in addition to checking to see the firewire card is properly installed. I would test the cable with another or ports. The D2 has a various array and combination of Firewire ports on each model. Also, try bringing the drive to another computer, to eliminate all other variables. Always of course, properly eject external hardrives and wait for confirmation whenever disconnecting it from the computer, and allow the drive to spin down before turning it off.
Sep 09, 2007 | LaCie (301146U) 320 GB FireWire 400...
Buffalo Technology DriveStation Combo 4 1 TB USB 20 Hard Drive Logo
60 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
