Question about Speed Queen AES28AWF Electric Dryer
Going from thre prong to four prong what goes
Going from thre prong to four prong what goes where
  • 8,197 Answers
Under the new Codesgoing from thre prong to four prong  what goes - 2_bing.gif...all dryers (and stoves/ovens) must now be 4 wire....having a seperate neutral and ground wire in NEW construction. In decades past, the neutral was allowed to serve as both - the neutral and ground - typically by means of a solid metal strap or wire strap that bonded that connection to the metal frame of the dryer. This sounds as if it is the case in your existing dryer...which was typical.
But...the old arrangement wasn't always reliable...and a seperate dedicated ground provides a greater safety path in the event of a fault inside the dryer (lowering the chance the user may get a shock when touching the frame of the dryer).
To modify your existing 3 prong dryer over to 4....you'll need to remove the 3 wire - disconnect the ground strap (or wire) that bonds the neutral to the frame of the dryer...and install your 4 wire so that you'll have (from left to right) one hot, one neutral, one hot connection...and connect the ground directly to he frame of the dryer (there is usually a green screw near the dryer connection block for this ground)
For more on this - with an illustration, see:
http://www.american-appliance.com/service_pages/electric_dryer_cord.htm
When done properly, you can test for correct wiring and connection with an ohm-meter (continuity check)...by checking for continuity from the ground prong on the plug to the frame of the dryer...you should see continuity. Then check for continuity from the neutral prong on the plug to the frame...you should NOT see continuity....nor should you see any continuity between the neutral connection at the wiring block to the metal frame.
The whole purpose of the Code change to the 4 wire is to seperate the two.
Hope this helps,....if you need more details, please follow-up.
Posted on May 02, 2010
I have a magic chef stove which has three prong and I just bought a he spectra glass top which it has four prongs could I use the three prong power cord on the glass top
tes you can use 3 prong the left and right wires go on left and right terminals on stove middle wire goes in the middle.
May 14, 2016 | Magic Chef Dryers
4-prong to 3-prong Power Cord Conversion.
On a 4-prong power cord you have 2 hot wires, one neutral wire, and one ground wire. On a three prong cord, you have 2 hot wires and one neutral/ground wire. The difference is the on four prong the neutral wire goes to electrical neutral bus in the breaker panel and the ground wire goes to the ground bus in the breaker panel. Since the neutral and ground buses, although separate, both go to physical ground, on a three-wire setup, you are just putting the neutral and ground wire together, Most dryers actually have a place at the pigtail connection to do just that.
Sep 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have thre prong dryer and four prong outlet
remove the old 3 wire cord from the dryer,purchase a 4 wire plug and cord that will fit the receptacle then put the RED and BLACK wires on the cord on the 2 outer terminals on the dryer or L1 & L2 terminals,then the white wire on the cord to the center terminal between the L1 & L2 which may be marked "N" or NEUTRAL,then finally the GREEN wire on the cord is thje safety GROUND and this connects to any metallic portion on the dryer case
Sep 12, 2012 | Admiral Dryers
How to connect a 4 prom receptical
Your four prong cord has 4 wires. Black,Red,Green and White.
Remove the 3 prong cord from the dryer.
The Black and Red wires go to the outside terminals on the dryer. The White wire goes top the center terminal. The Green wire goes outside the terminal cover to any nearby screw for grounding.
Jan 04, 2010 | GE DSKP233EWWH Electric Portable Dryer
Dryer cord
Jan 03, 2010 | Roper REX4634KQ Electric Dryer
Have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Mar 28, 2009 | Whirlpool Dryers
From three prong to four prong
Hello There,
your hooking up 2 Hots 1 Neutral and 1 Ground
240v
you need to consult a electrician for reason that 240 is a very high voltage and will kill you.
your outlet has to match your plug and how its wired into the Panel
Double Pole Breaker 50amp no less
2 hots go to breaker from outlet red / black
1 neutral goes to neutral bus bar in panel from outlet
1 ground goes to ground bus bar in panel from outlet
that equals your four wires
Mar 20, 2009 | Whirlpool LER5636P Electric Dryer
Install four prong plug kit
hi thanks for the question the green wire goes to the frame of the dryer other wires red to red white to white black to black thanks the appliance doc
Sep 15, 2008 | Kenmore 62872 Electric Dryer
Bought used dryer. Plugs don't match. Can cord be switched?
Yes, these cords can easily be switched. When you remove the three prong cord from the terminal block in the rear of the unit, you will wire the four prong in the same way. Black and red go to the outside terminals, white to the middle terminal, and the green wire goes to the cabinet or ground screw on the outside (usually, there is a greenish looking bolt around the terminal block door area for this to go). The only difference in a 3 and 4 prong configuration is the extra ground (green) wire. Good luck and let me know if you need further information.
Feb 01, 2008 | Maytag Performa PAV3200
Speed Queen AES28AWF Electric Dryer Logo
298 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
