There is power to the motor but it is just humming when turned on
SOURCE: am trying to open pool, motor hums but will not run
Sounds like COULD BE something (a small stone or twig) jammed in the impeller. See if you can spin it using a long screwdriver, if it moves, it is not jammed. If it spins, I hate to say it might be the motor is gone.
Testimonial: "good response, but have a follow up question regarding the answer I received - how can I pursue? thanks!"
You could also have a bad starter capacitor, and that's a cheap fix. If you end up getting a new or used pump to replace it try to get the same kind so you can use some of the old pump for parts in the future.
