Question about Car Audio & Video
I hit a hole on the road and the cd player stoped. I had to re enter my code and it worked, but the second time I hitted the road the radio just stopped working and the I only thing I see it,s the red light flashing when the car is on park and the ignition at off. I have a Blaupunkt CD business for a BMW Z3 2001 Supplied Serial : BP0273y8211997 Supplied Part No:7640273342
    President:
  • 1,561 Answers
Have you check all the wires that connects your cd player to the car battery terminal because most likely that one of the wires is removed or perhaps it is possible that during the process of you hitting the car in a hole on the road, one of the wires is detached from the connection, that is why it is flashing a red light.
I suggest you look at all the wire connection that leads the cd player to the car battery terminal to see if any is detach. if you see any, please connect it back to its rightful position.
Take care.
Posted on May 02, 2010
I need to unlock code for my kdc-mpv5025
Without test...
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Source: http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Good luck.
Sep 29, 2011 | AudioControl KENWOOD KDC-MPV5025 Car...
My battery in my car and now i need a code for my kdc-mpv5025
Without test...
1) Turn on the car.
Good luck.
What is the security code for kdc-891
You will need a Kenwood RC-410 remote control.
1) Turn on the car.
3) Press >>| and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>| key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>| key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>| key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>| key on the faceplate.
Jun 01, 2010 | Kenwood KDC-X891 CD Player
Cd is jammed in cd player, when i try to hit the eject button it tells me there is no cd. how do i get it out?
Turn the radio off and then disconnect the battery for 30 seconds. Make sure the radio is off or your going to be prompted to enter a radio code to activate it again. Once the battery is reconnected the radio can be turned on again and then try to eject the CD. Good luck and this should work.
Jun 25, 2009 | 2004 Mercury Mountaineer
How to reset radio cd hyundai HM-5064 using provided password
Hey there, lucky for you that you were able to obtain your passcode, unlike some of us.
To enter the code you hit the number 1 on your stereo w times, the number 2 x times, the number 3 y times, and the number 4 z times, then hit 5 once. Based on your code, wxyz. Ie if your code is 4316, hit 1 on the stereo 4 times then 2 3 times, 3 once, 4 six times, then hit 5.
Apr 11, 2009 | Car Audio & Video
Kenwood KDC-MPV 7019 code
Kenwood Code reset for KDC-MPV7019: (remote required)
1) Turn on the car.
MANUAL for the same radio
Jan 15, 2009 | Kenwood KDC-MPV7019 CD Player
Need to reset the code for a kenwood kdc-mpv7019
If You Have The Remote Here Is Your Solution.
1) Turn on the car.
Thank You For Using Fixya.com Please Don't Forget To Rate My Answer
Jan 08, 2009 | Kenwood KDC-MPV7019 CD Player
CD Error on Stereo (Not a code issue)
I have seen this a bunch of times always with the same result, take it to a audio repair facility, the sterio has a bad internal circut. No external "quick fix" that i know of
Nov 11, 2008 | 2005 Honda Civic
No sound!!!!!
sounds like you blew an interior speaker.. it would cause the radios internal amp to shut down.
Jan 17, 2008 | Panasonic CQ-C8303U CD Player
I need a security code
you need a remote for the KDC-MP628 for this to work.
1)Press >>| and Auto keys simultaneously on the faceplate and hold for 4 seconds.
2) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>| key on the faceplate.
3) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>| key on the faceplate.
4) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>| key on the faceplate.
5) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>| key on the faceplate.
6) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Jan 03, 2008 | Car Audio & Video
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
