Question about Whirlpool Refrigerator Inverter Box - 8201670
Fuse fail error diagnostics tells that when first three indicators on front panel blink and beep the fuse has failed and the battery wires short circuited . solution provided in manual is to correct the short circuit and replace fuse . how can the short circuit be corrected because the second step (replacing fuse) is easier to do and doesn't solve the problem.
    Guru:
  • 290 Answers
When we talk about a short circuit,it means that, there are two wires or cables touching or making a contact with each other.For example a red wire touching a black wire.
how can the short circuit be corrected?,
  1. Take a look at the wires carefully and see if there are any two wires touching or making a contact with each other.If there is any of such separate them.
  2. Check if there are any wires getting burnt. When wires burn they tend to come in contact with each other.If there is any burnt wires replace them or insulate them very well.
Do the above for the wires bringing the input into the inverter and the battery cables.
Note. a short circuit is a union or contact of two unlike poles like positive and negative,black and red
Posted on May 07, 2010
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Tip
Beep codes
Diagnostics with Beep Codes Following are the beep messages associated with the IBPbios. 1 short beep specifies a normal post 2 short beeps tells about POST errors that can be find onscreen. Continuous beeps indicates power supply and other cardserrors. One long and short beep indicates system board problems 3 long beeps defines keyboard errors No system beep tells about power supply errors.
on Mar 15, 2011 | Computers & Internet
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
second.
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Ibm 8215 beep codes
Here is a list of beep codes, this may help determine the problem wit your system.
1. Keyboard
2. System Board1-4-X Error detected in first 64 KB of RAM.1. Memory Module
2. System Board2-1-1, 2-1-21. Run Setup
2. System Board2-1-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-2-21. Video Adapter (if installed)
2. System Board2-2-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-3-X1. Memory Module
2. System Board2-4-X1. Run Setup
2. Memory Module
3. System Board3-1-X DMA register failed.1. System Board3-2-4 Keyboard controller failed.1. System Board
2. Keyboard3-3-4 Screen initialization failed.1. Video Adapter (if installed)
2. System Board
3. Display3-4-1 Screen retrace lest detected an error.1. Video Adapter (if installed)
2. System Board
3. Display3-4-2 POST is searching for video ROM.1. Video Adapter (if installed)
2. System Board41. Video Adapter (if installed)
2. System BoardAll other beep code sequences.1. System BoardOne long and one short beep during POST. Base 640 KB memory error or shadow RAM error.1. Memory Module
2. System BoardOne long beep and two or three short beeps during POST.(Video error)1. Video Adapter (if installed)
2. System BoardThree short beeps during POST.1. See "System board memory" on page 62.
2. System BoardContinuous beep.1. System BoardRepeating short beeps.1. Keyboard stuck key?
2. Keyboard Cable
3. System Board
Nov 29, 2011 | IBM ThinkCentre M52 8215 - P4 531 3 GHz...
I have an Amana PTH153B50AK - The heat is blowing cold. Can you tell me which part needs to be replaced?
If the room air blower only puts out what feels like cold air and continues to run all the time it is an indication that the unit has a fault code stored in its CPU or central processing unit (better known as the circuit board). If the unit has a small viewing port either on the front panel or just behind the front panel, you can look into it and see a blinking LED light. Count the blinks and record. Sometimes there may be short and long blinks such 1 short and three long blinks. This could be an error code 13 or 31 depending upon the manufacturer. On the reverse side of the front panel, there should be a wiring diagram that also has a diagnostic chart that will tell you how to read the codes and where to start looking for issues based on the error code you recorded.
hope this helps, please rate my answer.
Jan 30, 2011 | Amana Heating & Cooling
Instrument Panel Codes??
Yes, it's called a lamp fault code.
9 is not familiar to me. Call dealer service department and ask them what code means.
Here are codes for a 94 Aerostar. I don't have 91 Sable. Sorry.
Air Bag Diagnostic Monitor Diagnostic Trouble Code Priority Table Diagnostic Trouble Code Component/Fault Description — No Air Bag Indicator — Inoperative Indicator Circuit or No Battery Positive Voltage to Air Bag Diagnostic Monitor — Continuous Air Bag Indicator — Air Bag Diagnostic Monitor Disconnected or Inoperative 12 Low Battery Voltage 13 Air Bag Module or RH Cowl Side Panel Air Bag Sensor Circuit Shorted to Ground 21 LH Cowl Side Panel Air Bag Sensor Not Mounted to Vehicle Properly 22 LH Cowl Side Panel Air Bag Sensor Circuit Shorted to Battery Voltage 23 LH Cowl Side Panel Air Bag Sensor Circuit Input Feed/Return Circuit Open 24 LH Cowl Side Panel Air Bag Sensor Diagnostic Circuit Open or Low Resistance in Center Air Bag or Front Air Bag 32 Driver Side Air Bag Circuit High Resistance or Open 33 Passenger Side Air Bag Circuit High Resistance or Open 34 Driver Side Air Bag Circuit Low Resistance or Shorted 35 Passenger Side Air Bag Circuit Low Resistance or Shorted 41 Center Radiator and RH Cowl Side Panel Air Bag Sensor Circuits High Resistance or Open 44 RH Cowl Side Panel Air Bag Sensor Not Mounted to Vehicle Properly 45 Center Air Bag Sensor Not Mounted to Vehicle Properly 46 Open Splice Center Air Bag Sensor Ground Monitor 51 Air Bag Diagnostic Monitor Internal Thermal Fuse Blown and Short to Ground No Longer Exists 52 Backup Power Supply Voltage Boost Fault 53 Sensor Circuits Resistance to Ground or Internal Air Bag Diagnostic Monitor Fault — Rapid Continuous Flashing of Air Bag Indicator
Feb 25, 2009 | 1992 Mercury Sable
Error Code F - 11
F11 is a serial communications error that is associated with , central control unit (main computer) or associated wiring and the washer works intermittently . Just to be sure you will need to check all your wiring connections going to the central control unit To access follow these steps:
1. Unplug the washer.
2. Remove the three 7mm screws holding the top panel on. They are located along the top edge in the back of the washer. Once the screws are removed the top panel will slide back then lift up.
3. The Central Control Unit (CCU) is located in the central rear of the washer. You can't miss it. Make sure all the connections are plugged in snugly. Check ONE connection at a time.
After checking wiring harness, run systems diagnostics test by performing the following:
The diagnostics will run through a series of tests to include FILL, AGITATE, DRAIN and SPIN functions. , . You can push PAUSE/CANCEL any time to end diagnostics. Run this test several times. If anything fails you will get an "F" code in the display window. If the tests all pass, the unit will shut off, followed by an audible "beep" and the CLEAN light indicator will be lit. If you get successful results, then you know you probably had a loose wire somewhere. If the test fails, I would attempt to replacet the CCU. The CCU can cost as much as $220 depending on where you get it.
Sep 09, 2008 | Washing Machines
Won't start, just beeps - sounds like door switch problem others have had
The three short beeps could be part of the fault code. Check the owners manual and there are diagnostic sheets on the inside of the machine. I cannot find this fault code in my data base. What is the Model and Serial Number of your Dryer. Check the Power inside the machine at the power cord power connections. You should have 120V from both power terminals to the common terminal. There should be 240 Volts across the main power terminal. Another quest replaced the power cord. Hope to hear some good news soon.
InMrFixIt.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
COMPAQ M700 ERROR 101 I/O ERROR
Computer Post / Beep codes Beep Code. Description. Document. 1 long, 2 short, Indicates a video error has occurred ... One Long and Three Short Beeps.
Good Luck, please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Compaq Armada M700 Notebook
Whirlpool Refrigerator Inverter Box - 8201670 Logo
229 people viewed this question
Top Whirlpool Electronics - Others Experts
Are you a Whirlpool Electronics - Other Expert? Answer questions, earn points and help others
