Question about Dryers
Hotpoint TCD 970 completely failed
Mains ok to dryer
no lights on controller , all seems dead
    President:
  • 2,468 Answers
Check the terminals behind the incoming power terminal strip,this terminal block handles a lot of current and after time terminals burn off,it sounds like the neutral wire is burned or broken off which will give you these results you speak of,unplug the unit first before opening the access panel in back
Posted on May 02, 2010
Hotpoint ctd40 tumble dryer gone dead changed the fuse still dead any ideas ???
Check the mains lead for continuity! Thats making sure the lead to the dryer is not broke anywhere internally.
It may mean removing panel to get access to where the mains lead goes into the dryer, You can do this with power off, check with a multimeter that both the brown wire and blue wire as well as the green and yellow earth wire has continuity from the plug to the dryer!!
Mar 27, 2016 | Hotpoint Dryers
My washing machine hotpoint ultima wmd 940 is dead no power ,but the fuse in the plug is ok.
the mains lead normally goes to a connector block at the top of the machine then onto a mains filter both of these can fail ie burnt out connections ect check these out first remember to un-plug machine first
Nov 10, 2014 | Hotpoint Washing Machines
8KG ULTIMA TCD 980 condense tumble dryer : the excess water isn't going in the bottle
How do I change the belt on a Hotpoint condenser tumble dryer
Aug 25, 2013 | Dryers
Tumble dryer blows main fuse
check fuse rate on dryer if same rate. check dryer for amps if pulling to many will blow fuse, if dryer is ok check from plug in to fuse.
Jul 29, 2012 | Hotpoint Dryers
My hotpoint wm52 won't start ,its completely dead no lights ,have checked sockets,plugsand fuse all ok ,have also changed interlocking system still nothing
main timer is blown along the door lock tracks. you can repair it with a soldering iron and a small length of wire. It blew because the interlock went faulty
Mar 28, 2010 | Washing Machines
Wd645 has no power to on/off switch. changed plug
Could be mains choke. Mains power comes into mahine via wall socket /worth checking this then onto mains filter/Choke..then to switch..So if no power here check this..wish you well
Oct 07, 2009 | Hotpoint Aquarius WD640 Front Load...
F17 flashing
Ok, here is the service manual for your unit.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Dryers/TCD970P-19506725900_UK.pdf
This is a company out of the UK. I'm not sure if they have a number here in the us or where exactly you are located. If you are in the UK, I have included a link for you.
http://www.hotpointservice.co.uk/hs/pages/index.do
Apr 10, 2009 | Dryers
HotPoint DLB2650BELAD Dryer overheating
You have a blockage in the heat baffle. While this is not difficult to clear, this is more than I can explain on a forum like this.
Nov 16, 2008 | Dryers
My oven has completely stopped working
hi there as long as your supply to the cooker is ok the problem can only be one of two things the mains terminal block burnt out or the overheat cutout has blown at the back of the cooker
Nov 30, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Dryers Logo
210 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
