Question about Oster 4724 Rice Cooker
How to open
Does anyone know how to open the bottom of this rice cooker. Do i go from the bottom side or take the hotplate out from the inside?
There is one screw to remove and the botton just pops off. NR
Posted on Jul 28, 2008
SOURCE:
How to used to cook white rice?
Hi
my rule for cooking rice is 1 part rice: 2 parts water big pinch of salt. This can we'll be done in the micro. Set it for 10 minutes, open the door and wander how the rice is doing. Take a fork. Put into the rice and find out how cooked it is. You will probably need another 10-15 minutes. Depends on the micro.
With a rice cooker it is much more accurate. Look inside the inner pot ,on the one side there could be numbers for cups of rice and on the other side for cups of water.
I hope you can find your answer here Food Steamers Rice Cookers Oster
all the best
kolbrun
May 03, 2016 | Oster Kitchen Appliances - Others
Where can I find the instructions Manual?
To insure long life and satisfactory performance from your Nordic Ware Rice Cooker, follow these simple guidelines (microwave use only).
1. Before using your Rice Cooker wash it thoroughly by hand in warm soapy water or in the dishwasher (top rack only).
2.Foods with strong colors (particularly red sauces, tomatoes) may stain your cookware.Staining that may occur will not affect the use of the cookware.
(Cooking times may vary due to variations in microwave ovens.Adjust cooking times for best results in your oven.)
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2.Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
HELPFUL HINTS TO ENHANCE THE FLAVOR OF ANY MICROWAVE DISH:
1. Use chicken broth instead of water for added flavor.
2. Add a little butter or oil to contents.
Jul 30, 2014 | Nordic Ware Kitchen Appliances - Others
When I plug in the rice cooker it doesn't turn on. What could be the problem?
Try to replace AC cord, then plug to another live wall outlet if not working, problem is inside the unit,remove to to the outlet, carefully open the bottom side check wiring connection for loss connected, or Bring your Unit to the nearest Qualified technicians.
Aug 02, 2011 | Zojirushi NS-TGC10 Rice Cooker
Hi, My Tiger Rice Cooker did not cook, although it's LED (RED light came ON), Pls help me
wiring problem, carefully open the bottom side of unit, check all wiring for loss connections. unscrew everyone bolt then check wires carefully.. if done try it..if not work' .bring your unit to the nearest qualified technicians.
Jul 26, 2011 | Tiger JAE-A10U 5..5-Cup Rice Cooker
Where i find sunbeam rice cooker fuse in midrand
sunbeam rice cooker dead
I have a sunbeam rice cooker working fine and all sunden there no power on the rice cooker. I have test the wall outlet power input which is working fine. I assume the fuse inside the rice cooker burn out the fuse. I could not located the fuse from the inside as opend up everything from the bottom panel rice cooker .Please email to me at [email protected]
thank you
Jun 03, 2010 | Rival RC160 16-Cup Rice Cooker
Does steam tray/lid go on top or bottom of rice cooker?
The steam tray as you call it goes on the inside bottom of the cooker. It's purpose is to keep the cooking rice separated from the heating element during the steaming process. The basic measurement is 2 parts water to 1 part rice. Add a quarter cup more water for brown rice. The automatic shut-off won't turn off until the water is gone. It's magic! Cleaning; soak the cook pot and perforated plate to remove rice goo DO NOT USE STEEL WOOL PADS or abrasive cleanser. I use a nylon dish cleaning brush to remove the stuck on brown material.
Mar 14, 2010 | Panasonic SR-W06NA 3-Cup Rice Cooker
Rice cooker keep feature turns rice crispy
This sounds like the thermostat inside the unit has went out and is overheating whitch in turn is cooking your rice too fast and too hot! if the thermostat is replaced it will cook the rice even again!
Please rate my response to your question
Thank You!
Jan 07, 2009 | Sanyo ECJ-PX50S 5-Cup Rice Cooker
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
Cooking Pasta:
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
No manual or instructions
I know the exact model you are talking about! I have one myself....Basically it is always two parts water to one part rice using the same measuring cup to measure both! So if you decided to use it for 6 cups total it would be 4 cups of water and 2 cups rice.....As for veges, You would fill the bottom of the inside pot just enough to where it doesnt touch the other pot that goes inside with holes to hold the veges and you can add a little salt, But then you close the lid and press the cook button and when it finishes it makes a quick and easy dinner side!
Jun 22, 2008 | Kitchen Appliances - Others
Spoiled rice after 20+ hours
I know this thread is old but after much research and trying all the crazy theories on sanitizing the rice cooker I have solved the problem and it should work for you too. EVERY person I've shared this with has reported the same results, rice that keeps for up to a week, nice and hot in the rice cooker as it ALWAYS has, the way you remember when you were a kid.
The problem lies not with the cooker itself but in the water you're using. Yes as simple as that. Let me give you a brief overview. You probably don't know but the tap water you're using most likely is treated with a compound called chloramine. The problem is this compound is also subject to a biological process called nitrification which in turn leads to an accelerated biological process in your rice cooker. This is a very high level explanation and there is much more detailed scientific explanations of the process and issues that are exacerbated by the pipes in your house and at the plant. I will not cover all the technical aspects but if you're wondering why this didn't happen before it's mainly because water was treated with chlorine before, not chloramine.
The bottom line is this. Rinse and cook your rice using ONLY bottled spring water, check the label. If it indicates the bottled water you're using is from municipal sources, call the manufacturer to make sure there is no chloramine. If you do this you will be so relieved and happy, I'll be happy knowing I saved you the frustration and brought rice peace to your life.
Forget about all the special cleaning procedures or equipment testing, I too thought there was something wrong with my fuzzy logic cooker...NOT!!!
If you want more in depth information about chloriminated water you can join my Facebook page and read/discuss it: https://www.facebook.com/pages/Chloramines-and-You/339649646128698
Mar 10, 2008 | Zojirushi NH-VBC18 10-Cup Rice Cooker
Oster 4724 Rice Cooker Logo
173 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Irene Tulloch
Marvin
Marvin
qtp2t4474
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
