Question about Samsung N13013B Netbook
How do i wake my laptop up from hibernation - Samsung N13013B Netbook
    Scholar:
  • 63 Answers
Just press the power button. Now the laptop will come back from hiberanation. Its as same as powering up after shutdown.
Posted on May 02, 2010
Hp550 computer not going to sleep mode properly
No matter which model of HP laptop you own, battery life is a big issue. Hibernation mode is designed to increase the battery life of your HP laptop by switching off the monitor, hard drive and other parts of the unit after they have been idle for a specific period of time. While hibernation mode works well most of the time, in some cases, your HP laptop may not wake from hibernation the way it should.
Docking Station Issues Many hibernation problems are caused not by the HP laptop itself but by the docking station to which it is attached. Some models of docking station interfere with the normal operation of the hibernation on the HP laptop. The easiest way to test this is to remove the laptop from the docking station and allow it to sit until hibernation begins. If hibernation mode works with the laptop undocked but not while docked, you know the problem lies with the docking station instead of the HP laptop. b> Remote Desktop Issues If you need to connect to your HP laptop from elsewhere, it is helpful to reset the power settings to the Always On mode before you leave your home or office. Many models of HP laptops do not wake properly from hibernation when users connect to them remotely using the remote desktop feature of Windows. When users connect with remote desktop, the program sends a signal to the remote computer that should wake it from hibernation and allow it to function normally. However, this process does not always work as intended with HP computers, so it helps to change the power settings to allow a seamless connection. Video Drivers Problems with HP laptop hibernation also can be caused by a corrupt or outdated video drive. HP laptops come with built-in video processors, and the drivers they use are installed during the initial setup of the unit. If there is a problem with that driver, HP releases an update, so if you see problems with hibernation, your first step should be to check for an updated video driver. b> External Keyboard and Mouse Sometimes the HP laptop does not respond properly and does not wake from hibernation when you use the built-in keyboard and touchpad mouse. The sensitivity of HP touchpads varies from model to model, and that sensitivity can be reduced over time. You can test for this problem by attaching an external keyboard and mouse to the laptop to determine whether that resolves the problem.
Feb 20, 2013 | Computers & Internet
Laptop will not wake up from hibernation
ok try this
turn off computer
press power button with battery and adapter removed for 2 min should clear the power settings
plug in adapter only(no battery)
turn on computer see if it's happier
if so, then install battery and restart
May 22, 2012 | ASUS K52F-BBR5 Notebook
Not wake from sleep or hibenate
Usually, to wake from sleep pr hibernate, you just need to press the "Power" button of your laptop. It will not turn it off or restart the laptop if it is in the "sleep" or hibernate mode. Pressing any key usually wake it up. The default way is to press the power button as if turning it ON for the first time.
Feb 11, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
My computer won't wake up after going into
HI, i suggest you unplugged your system from the AC outlet and leave for sometime to rest, power it on back after few minutes and put on your system.
Doing this will help wake your system up from hibernation.
I wish you best of luck.
Jan 07, 2010 | IBM ThinkPad R40 2722 Notebook
My Samsung N10 is turning on from stand-bye by itself. Any solution?
Most likely you are touching the keypad or mouse and it thinks you are waking it up. You might try selecting hibernate instead of standby which will put it to sleep and won't wake up until you press the power button. If you don't have the hibernate choice you'll need to go into your power settings to enable hibernation.
Dec 17, 2009 | Samsung NC10-14GW Notebook
Hp pavilion dv4000 will not wake up from hibernation
You have major problems. You should take it to a repair shop as it sounds like your motherboard is fried.
Oct 22, 2009 | HP Pavilion dv4000 Notebook
Cannot wake up computer after putting it to sleep -- HP Pavilion -- I have pressed every concievable key combination ? Computer may be waking, but monitor is blank.
I rebuild these systems all the time and I have to tell you I just shut off the hibernation which is what the problem is. Go to power options in the control panel and click the hibernation tab and uncheck the box. That way you save the disk space and the aggravation of trying to wake up the system. Let the computer go into standby if you want but you really need to turn off the hibernation...
Oct 05, 2009 | HP Pavilion dv6000z Notebook
Can't wake up after hibernation
press teh power button at least 6 seconds
and turn it on
Jul 15, 2009 | Acer Aspire One Netbook 8.9" Notebook
Not waking from stand by on windows xp sp3
dont keep doing it, at some point your laptop wont ever comeback to life. so just use shutdown and hibernation
Mar 25, 2009 | HP Compaq nx7300 Notebook
Acer is in hibernation
navigate to control Panel>>power options>>Hibernate tab and uncheck the Enable Hibernate mode and restart the system and if it still does the same then please contact your system admin
Aug 04, 2008 | Acer Aspire 3680 Laptop
Samsung N13013B Netbook Logo
125 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
