Question about Dell Office Equipment & Supplies
In copy mode (this error has never happened before) When trying to copy a doc get the following: Illegal settings. This is unavailable when tray (no paper) is selected. Settings are correct and there is paper in tray selected.
5 Suggested Answers
NotAsUsual
  • 43 Answers
SOURCE: paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Posted on Dec 01, 2007
  • 214 Answers
SOURCE: How do you change the paper selection?!?
if you have a different size/type paper in trays, just choose auto tray from printing preference, you only have to put right paper type /plain/thick ..... and the printer find it self the right tray
Posted on Nov 12, 2008
  • 44 Answers
SOURCE: Can't print onto thick card
In your print driver, you need to go to the Printer Features -> Media 1 window and specify "Thick 2" and then go back to the main print window and specify Paper Feed "Tray 2" Then go to the copier,, place the stock into tray 2 and match the paper setup for that tray on the copier to "Thick 2" for tray 2.
Basically, both the Mac and the copier need to match paper types and feed tray.
Posted on Nov 17, 2008
  • 523 Answers
SOURCE: Can not get the output tray to use the finishing tray.
Do you mean you have internal finisher? Try to make any copy with staple it should comes out from there, if not you have to go to machine setting or copy setting , you do this by pressing menu buttom, and change the output paper to the internal finisher.
Let me know wat happen after.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Mar 24, 2009
"Set unavailable" error received when I tried to Set Copy on Norstar M7310 phone
Are you sure you have the correct extension number for the destination? I may be more than "not progammed correctly" - perhaps it isn't the ext# you think it is. Try Feature*0 then all the keys, especially the line keys, which should give you the extension number.
Apr 21, 2015 | NorStar M7310 Corded Phone
Error Code
the pw sensor on the cr assy is dirty.clean it.
move the printhead with your hand and place it to the right end and turn the printer on....
maybe will work...
Apr 29, 2014 | Epson Office Equipment & Supplies
Illegal settings , this is unavailable when (the tray) (no paper) us selected,
Go to setup, default settings, copy, scroll down to paper tray (using left and right arrows) select tray 1
Jul 30, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
My brother MFC-230C is unable to clean. I went to the maintenance chapter and followed the intructions but am still having problems.Please assist me.
There should be an "error number" flashed in your LCD. If "Unable to Clean, Error ##" appears, troubleshooting should be based on the error number.
But I think it's all about the "counter" of your Brother Printer. Try resetting it by turning your printer off and turning it on in "Maintenance Mode". To enter into maintenance mode, do either of the following;
1.) Press Menu, Mono Start and Up arrow the shortest time possible when turning the printer on. 2.) Press Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
You'll know you're in Maintenance mode because all the four buttons in Photo, Copy, Fax & Scan will flash. when you're in Maintenance Mode, press 80 in your number keys, then press "Mono Start" (Black Start) several times until you reach to "Purge Counter" which is in the 25th option. To reset your counter, press 2, 7, 8, 3 in order and you should notice your purge counter back to zero.
Please "Stop" several times to return to main menu of maintenance mode. To exit maintenance mode, press 9 twice to return to standby mode. Power it on and try cleaning or printing a doc again.
Hope this helps...
Jun 03, 2011 | Brother Office Equipment & Supplies
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Ricoh Aficio 1045 error message SC726
Hi
Thanks for using FixYa. Error Code SC726 means the Finisher shift tray 1 lift motor error. You need to enter service mode and reset the unit by following the instructions given below.
To enter service mode (SP): Press the clear mode key then enter 1-0-7 hold down the c/s for three seconds. To enter the special service mode you’ll need to hold the # key down while pressing Copy SP. Exit service mode: by pressing exit twice. It will reset the and cycling the power.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 24, 2009 | Ricoh Aficio 1035 Copier
Mar 24, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Can't send or receive fax
Your product must be accidently set to copy mode instead of fax mode and when it is, it actually expects a document to be loaded in the tray to "scan/copy" so change to fax mode again and try to sent the document. This should fix your problem.
If you do want to make a copy, make sure a doc. is loaded and press start copy to do so.
Jan 06, 2009 | Canon FAX L-120 Plain Paper Laser
Question Mark
That means the code calls for an image but can find the file to load.
Apr 21, 2008 | Apple MacBook Pro Notebook
164 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
