Question about Maytag MSD2454G Side by Side Refrigerator
Coils in my 2454 packed solid with ice. Thawed it out....worked fine for a couple of weeks. It quit staying cold so I dug behind the freezer to discover the coils again encased in ice. Thawed it yesterday and works fine again but I really don't feel like thawing it every couple of weeks. Defrost sensor??
    President:
  • 2,468 Answers
Your defrost heater around the coils is open and can no longer heat,or the adaptive defrost timer or defrost thermistor are defective located in the refrige control panel behind the temp controls and the thermistor is located on the defrost heater assy
Posted on May 02, 2010
Refrigerator will not stay cold and ice is building up in freezer.
your compressor or condensor or capacitor is bad, need a technician
Dec 11, 2015 | Maytag Refrigerators
Gladiator Freezerator wont stay frozen in the bottom portion. It will go to temp when temp is mved, but then start to warm up. Why?
If the bottom freezer section of the Gladiator Freezerator is thawing out the usual cause is from the coils in the back of the top refrigerator section being iced up. The ice blockage prevents the fan from circulating cold air into the bottom freezer section. These units have a design flaw due to the defrost drain freezing up preventing water from draining out from under the coil. The long-term solution is to remove the back wall of the refrigerator section to get to the coil, thoroughly defrost the coil making sure the drain tube is clear, then wrap a couple turns of #12 or #14 copper house wire around the bottom of the defrost heater element and run it a few inches into the drain tube. Advise unplugging the unit when you do this.
I've had this fix on my Gladiator for a couple years and it has been working perfectly ever since. The freezer stays a constant 0 degrees F and no more thawed out food.
May 09, 2014 | Gladiator Freezerator Top Freezer...
My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
Aug 05, 2010 | Whirlpool Refrigerators
Freezer works now and fridge still warm
your right the air is not getting through the cold coil / when you defroated it . did you remove the back of freezer . if not there is still 2 in of ice back there blocking the air flow/ now a good defrost is needed but you need to correct the problem of why this happened . either the timer / heater or defrost termminator is bad . usualy its the heater.. mm hope this helped .. feed back pls
Feb 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Need some help. have a kenmore model no 53606201 made in 6/02 that is having problems with the refrigerator. The top two shelves barely cool down. We cleaned the coils underneath, front and back (they...
Sounds like the freezer fan may not be working properly. This fan must rotate to move cold air from the freezer to the refrigerator.
This fan is probably behind an access plate in the freezer. You likely could hear it if it's running. Remove the plate and look at it to be sure. If it's not turning, you will need to replace the fan motor. These are readily available.
Oct 14, 2009 | Refrigerators
I WAS ON YESTERDAY WITH THE SAME APPLIANCE A JENN AIR REFRIGERATOR JCD2389GEB. I NEED TO START AT THE BEGINNING. EVERY COUPLE OF WEEKS MY REFRIGERATOR ON TH ICE BOX SIDE WOULD GET WARM THE FREEZER WAS...
What you started out with was a defrost issue,adding freon made your problem worse,pressure on the low side when fully charged should be around 0 to 3 lbs.
 the most common problem with theses units is the adaptive defrost control sits in the refrigerator section top right corner above the white plastic cover.part # 61005988 runs about $70.
 Second most common defrost issue is the defrost thermostat # 61006199 runs around $45 comes wired in with the heater assy sits behind the wall in the back of the freezer. But first you need to get someone to evacuate the system and put in the right charge it will be on the model number tag on the ceiling of the fridge it's somewhere between 4 and 6 onces not pounds.
Sep 23, 2009 | Refrigerators
Frig and freezer wont stay cold,defrosted 2 weeks ago and it was working ok ,but its happening again ice on the coils
change the heating element located in the freezer. It is behind the panel inside the freezer to the bottom. These are known for this.
Jul 09, 2009 | Refrigerators
The freezer is warming up
If you found something lodged in the door that may have kept it open for a while, i suspect frost formed on the coils behind the panel. Frost will not let air pass through the coils to the refrigerator side. This is one of the most common problems there is. If you look through the louvers on the rear panel that is for sure your problem. It most likely just needs thawed out. After it is thawed out, your normal defrosting routine will take over again and hopefully you will be trouble free again.
May 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
ICe build-up on coils and frezer does not freeze after a few weeks from thawing.
Check the defrost timer which may be behind the kick-plate, inside the control panel or an Adaptive Defrost Control (motherboard) on the back.
Apr 22, 2009 | Refrigerators
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Maytag MSD2454G Side by Side Refrigerator Logo
383 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
