Question about Sylvania Televison & Video
Motorola rg 2200c Gateway Universal remote
Is there a universal remote that will work with the RG-2200c Gateway
Problem is the src-350a remote will note work with the TV I just bought
Ser#
Sylvania LC320SLX
SOURCE: Sylvania TV
i had a sylvania tv and i accidentaly cracked my remote... i got this remote and it will work for a little wile then it will stop working for a wile, then it will work and now its been a wile and i forgot the code for this tv.... i only wantthe code but i cant find were to get it... i will try codes from other sites but they dont work
Posted on Jan 24, 2008
SOURCE: Universal Remote Code Needed
The code is 11963.
Posted on Apr 06, 2008
SOURCE: iwave big universal remote codes
I need the codes for the Phillip Magnavox tv combo.
Posted on Apr 07, 2008
SOURCE: Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Posted on Jan 16, 2009
SOURCE: universal rca remote rcr312w codes for sylvania tv
the code for sylvania rcr312w is 1192
Posted on Apr 20, 2009
I am using hp rg-0983 device but i want to connect my bluetooth beats headset to it how can i connect please suggest?
You need a blue tooth dongle made for the beats headset. Keyboard and mouse dongles are not universal. They work only with the keyboard and mouse that it was designed to operate with.
Sep 21, 2016 | Radio Communications
I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
Need free service / repair manual for rg 250 2-stroke 84-88
tradebit.com claim to have an Suzuki RG 250 manual for US$15 for download.
May 22, 2010 | 1986 Suzuki Rg 250
I cant get all of my cable channels. i dont have the remote to the tv. i have a universal remote that will pull up the tv menu but wont scroll through it at all
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Vitally
Jan 21, 2010 | Sanyo 52 ROBUST LCD MONITOR CE52LH1R LCD...
Sound like "gırgırgır"
Your cam chain tensioner needs to be replaced mine has been done twice.
Feb 18, 2009 | 2005 Yamaha FJR 1300
Jensen tv not working with direct tv universal remote
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Jan 10, 2009 | Jensen TS2050J 20" TV
Remote Control Code for Motorola Cable Box
I have a Motorola cable box and used code # 051. Works great. Can't find a code for DIGISTAR tv though. If anyone has one, shoot it to me at deannescollard@hotmail.com.
Feb 22, 2008 | Motorola Mobility DRC800 Universal Remote...
Lost codes for 4 in one used for universal remote control
DRC800 Sanyo TV 0799,0154,0893 Panasonic VCR 0035,0162,1062,0616,0225,1035 press device key for 6 seconds led will blink solid key in code correct code will cause led to blink 3 times press power button to confirm code works. rg
Sep 09, 2007 | Philips 8-Function Universal Learning...
Televison & Video Logo
62 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
