Question about Jenn-Air JXT8136ADS Kitchen Hood
Changed a buld in hood and it touched casing as I was inserting. Tripped the breaker. This is reset but now have no power to bulbs or fan. Is there a trip in the hood?I dont have the model number, it is a jen air unit
    President:
  • 2,468 Answers
Check to make sure you have power back to the junction on the hood,sometimes just resetting the breaker wont do the trick,it may be a wire at the hook-up open now,there may be a fuse protecting the unit itself for the fan control,but the lights are usually wired direct so re-check the incoming power first
Posted on May 02, 2010
Light bulb flashed out when putting it in and i cannot get the fan or lights to work
It is possible that the circuit breaker tripped when the bulb was installed remove the bulb and assume that the bulb is defective. Go to circuit breaker panel and check for tripped breaker.
Jan 09, 2016 | Dryers
Turned of the light on my hood and nothing worked after. No light no fan.
Some units have a reset button on the unit some place Check and see if you have one and push to reset. Hope this works for you.
Sep 15, 2015 | Venmar Kitchen Ranges
Whirlpool accubake
follow this steps with VOM and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangehood-repair-help.html#ixzz2aSy5FKwN
Jul 29, 2013 | Kitchen Ranges
Nec vt695
Did you unplug it before you replaced the bulb?did you touch the bulb?are you sure the bulb works?have you reset the lamp hour meter?did you replace all doors, screws and original parts?is the bulb securely in place?
Here is your manual http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf
Mar 29, 2013 | NEC VT695 LCD Projector
Honeywell MagicStat 3200 Fan continues to run--I flipped furnace breaker off for an hour, set stat to off, & flipped breaker back on. fan still runs. Fan control is on Auto.
Hello,If just installed the thermostat check that the wires are not touching anywhere.If not the case you have a open(tripped) HIGH LIMIT at the furnace and the blower will continue to run untill it is reset.
Oct 30, 2010 | Honeywell Programmable Thermostat Heater
Put new bulb in baumatic kichen hood turned it on, instantly made a noise like it tripped out, fan and lights now don't work, can not find fuse?
It was probably a defective bulb that tripped a circuit breaker in your house panel. Check the breakers and replace the bulb.
Feb 24, 2010 | Baumatic F60 Stainless Steel Kitchen Hood
How do change head lite
okay, I have a 94 Camry and I imagine it's the same way. Open up the hood look behind the headlight and locate the bulb actually the buld holder then twist it the holder to remove it and the bulb. Then just pull the bulb out. When replacing with a new bulb people recommend wearing gloves as your hands shouldn't touch the neon bulb as it leaves oil on the bulb. Just plug the new bulb in put bck in place and turn to secure it.
Oct 29, 2009 | 1995 Toyota Camry
Neither lights nor fans work
don't know model but they are all much the same.
there will be a pcb behind the control buttons and you will find some of the track burnt out causedd by the bulb blowing. do a soldered wire link across the burnt section of the track
Sep 25, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Jenn-Air JXT8136ADS Kitchen Hood Logo
206 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
