Question about Amana ATB2135HR Top Freezer Refrigerator
Fan in freezer not working, is there a reset button? If so, where is it? ice cubes not freezing solid. frozen food slowly thawing.
    President:
  • 1,218 Answers
Good day,
No reset button. Most likely the fan motor failed. You will have to remove the rear panel in the freezer to test it.
If it has 120 volts going to the motor, then you will have to replace it.
However, if it is an older version, it is possible that it is controlled thru a freezer door or fresh food door switch.
On a limited number of Amana's, the motor was held off by the defrost thermostat ( a round 1" disk clipped to the top of the cooling coil.) The purpose was to allow the coil to cool down after going thru a defrost cycle.
The second 2 causes are for older machines only.
Posted on May 02, 2010
    President:
  • 2,468 Answers
No there is no reset,you need a new evaporator fan,because they burn out the windings and theyre not very expensive
Why is ice frozen solid in the bin?
The ice could be caused by a partial thaw such as a power failure. To open bin unplug unit. Get lots of towels and a wet Vac if you have one. The use of these will become obvious shortly. Open the door and put a fan blowing on it, the same type of fan we use when it is hot to cool down. Then wait in time it will start thawing. This would also be a good time to clean it inside, you probably were putting that off. When totally thawed and dry start it up and keep an eye on it for a few days it will probably be ok. If not you have a clean unit to try some of the other suggestions.
May 27, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frozen freezer water line
Odds are your temperature is too cold in your freezer. If when you moved you just plugged in your freezer without adjusting your temperate for your new location you accidentally froze whatever water was coming into your freezer.
First you will need a cooler for whatever you have in your freezer, unless you have wonderful neighbors who will let you keep your food in their freezer for couple of days.
Take note to see what your freezer thermostat is set to. Turn off your freezer. Take out all the food. Keep the door open. This would be a great time to clean your freezer. Let the freezer thaw out for at least one day. Check the line to make sure there is no ice. Once everything has melted turn your freezer back on. Turn your freezer back on but this time set the thermostat to three or maybe 4 levels below what you had it set to before.
Finding Freezing level:
Fill an ice cube tray or small plastic cup with water. Put it in your freezer and come back in about three hours to see if has begun to freeze. If it has not begun to ice raise your thermostat to make you freezer colder by half or 1 level. Leave the ice tray or cup of water that you originally placed in the freezer but add another one. Come back in three hours to see if the water has frozen or has begun to freeze.
You want to leave the original water because you need to make sure the new water does not freeze solid as fast as the original water. If it does your freezer is too cold again.
Repeat "Finding Freezing level" until the water begins to freeze but does not freeze solid. Once your ice begins to free you can put your food back into the freezer. Wait a couple of hours more to see how much more your cubes freeze. If they are hollow or still watery in the center you should go up another half level and check on it the next day.
Once your cubes freeze solid you should be all set. If you don't get at least one tray of ice per day from your freezer you could go up another half level so your ice freezes faster.
Be careful about making your freezer colder because you might end up with the same problem you started with depending on how sesitive you thermostat is.
May 03, 2012 | Maytag MSD2578VEM (254 cu ft) Side by Side...
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Our 2 1/2 year old GE side by side frigerator has worked fine in the past, but now the top part of inside the freezer thaws part of the time. The ice cubes partially thaws then refreezes into a solid cube,...
hey i got disconnected do me a favor AND CLOSE OUT OF THE CHAT SESSION AND PLEASE RATE IT FOR ME I WILL FINISH UP EVERYTH ING FROM HERE SO YOU WONT HAVE TO PAY FOR IT AGAIN
Apr 24, 2010 | Refrigerators
Ice Cream won't stay frozen it get's all soft and gross. Main things in the freezer stay frozen.
This is an easy one!!
Ice cream needs to be around -5 degrees to +5 degrees to stay frozen (or hard) if the freezer is at like 15 degrees the ice cream will be soft but the rest of the things like meat and ice cubes will be rock solid because anything lower than 32 degrees is freezing for those things.So you might wanna check to see if the fan motor is working and also make sure the condensor coil is free of debris.
Sep 20, 2009 | Refrigerators
The freezer is warming up
If you found something lodged in the door that may have kept it open for a while, i suspect frost formed on the coils behind the panel. Frost will not let air pass through the coils to the refrigerator side. This is one of the most common problems there is. If you look through the louvers on the rear panel that is for sure your problem. It most likely just needs thawed out. After it is thawed out, your normal defrosting routine will take over again and hopefully you will be trouble free again.
May 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The coils are frozen solid in freezer behind back wall
frozen coils not always means freon problem. low air flow across evaporator coils could cause freeze up. if door is opened and closed an abnormal amount could cause a freeze up or even something pushed up against the air intake in the refridgerator. i would thaw it out completely and restart it, theres a chance it was nothing major. good luck
Jan 12, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Frigidare ice maker making slabs of ice, not cubes
Today, I removed ice maker and auger motor. Found out this morning that water was running down the back of frig. inside, everything in freezer was frozen together. Found this out after removing all food from freezer. When i looked into the ice maker where water enters, that was frozen solid. After thawing and checking everthing. I put it back together in freezer. It is nine oclock now, and I do have cubes. I really can't tell you what I did, except thaw it all out. It's been running for four hours now and it seems to be all right.
Nov 16, 2008 | Frigidaire Dryers
Freezer not freezing
The evaporater is located in the freezer section of unit.Defrost thermostat is cliped on the top of it. This is no doubt the culprit. You will need to check continuity on defrost heater and replace themostat.
Jul 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana ATB2135HR Top Freezer Refrigerator Logo
215 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
