Question about Bissell 3750R Air Conditioner
Bissell lift off bagless tripped breaker. Cut
Bissell lift off bagless tripped breaker. Cut out, possibly overheated, when I last used it and now no power. Where is the breaker switch?
    Problem Solver:
  • 5 Answers
If it overheated, there is a automatic switch in or near the motor that resets automatically...if its cooled and wont start back up??? Then check that your outlet has power to it. if not, reset trhe house breaker and if it does, start hitting garage sales for 5 dollar vacuums....
Posted on Oct 09, 2010
Where is the reset button on the Bissell Powerforce helix upright ?
This unit does not have a reset button or fuse that is accessible or repairable. If you are referring to the manuals troubleshooting no power, the blown fuse or tripped breaker that is being referred to in the manual is your house hold breaker box and the fuse or breaker that handles the outlet the unit is using.
If your having power issues you should first inspect that all accessible parts are functioning. Such as hoses being closed, dials resting in the set positions, wand locking. Also if visible the sensors that are keeping tabs on each part. Another issue may be that the cord had been kinked and has shorted out, one possible way to check this issue is: if the unit powers up only when the cord rests in certain positions.
If this was recently purchased the warranty is for one year. A ship repair cab run $35 to $100+ you will have to call around. Or have a handy family member you with it.
Being these machines can be found $50 to $75 a replacement would probably be your best bet.
e72fb1da-2558-49cd-81a9-99825035337b.png e48073ba-4f6c-40a2-92a7-244dedbcfce5.png
Aug 03, 2014 | Bissell 6594 PowerForce Bagless Upright...
No power to Bissell 3750-E
I'd test the new fuse with a meter. I'd then plug it in and retest for power and ground to and through the switch and motor. It could be as simple as a loose or pinched wire which grounded out.
Dec 07, 2013 | Bissell 3750 Lift Off Bagless Upright...
Bissell bagless vacuum just stopped working
the most likely to be overheated the motor, or cut the cord.
for the first unplug the power supply and let it COLD, ALSO CAN SWITCH AUTOMATIC OVERHEATING or proving or proving MANUAL. for the second take the machine to an electrician to check out the cable.
Nov 28, 2013 | Bissell PowerForce Helix Bagless Upright...
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Bissel vacuum will not turn on
Hello, this is Ava with Think Crucial.
One of the possible causes that your Bissell won't start is that power cord may not be firmly plugged in so you may need to check electrical plug. You may also want to check or replace the fuse or reset the breaker in case there is blown fuse or tripped breaker.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 16, 2012 | Bissell 6594 PowerForce Bagless Upright...
Removing the filter
Hi There,
Here's a very helpful video that shows you exactly how to replace the filters on your Bissell Lift-Off Bagless Upright.
Please leave some feedback if you found this helpful, thank you!
Video showing how to replace the filters on your Bissell:
http://www.bissell.com/VideoRating.aspx?id=1554
Hopefully that helped you,
Chris J.
GoVacuum.com
Apr 14, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
Vaccum problem
No sound at all? or the motor runs but no vaccuum?
did it stop while using it? might have overheated due to dirty filters... strange that the light comes on but no motor at all... that would suggest to me that the motor is shot...
Here is a link the the manual.. there is no reference to any user accessable fuse or breaker...
Peace,
Mar 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
My Bissell vacuum cleaner won't turn on.
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Dec 29, 2009 | Bissell 6594 PowerForce Bagless Upright...
Overheating
check filters and for blockage - poor air flow then will overheat
Aug 21, 2008 | Bissell 6594 PowerForce Bagless Upright...
Heating & Cooling Logo
142 people viewed this question
Top Bissell Heating & Cooling Experts
Lawrence Oravetz
Tom Chichester
Are you a Bissell Heating and Cooling Expert? Answer questions, earn points and help others
