Question about Bosch Axxis WTA 3500 Dryer
Why does my bosch dryer wta 2910 only blow cold air?
    New Friend:
A mi aun me sale frio, incluso despues de haber limpiado
Posted on Dec 01, 2013
  • 10,319 Answers
If the exhaust vent tubes have never been removed and thoroughly cleaned in years this will cause the sensor to keep the heat off in your dryer. If clean the moister sensor is at fault
Posted on May 02, 2010
Dryer runs, rotates, and air blows but does not blow hot air, therefore cloths will not dry.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 13, 2011 | Bosch Axxis WTA 3510 Electric Dryer
I have a Bosch Axxis WTA 3510 dryer. The dryers heating coil stopped working. While looking on line I was able to fix the problem by using the reset button at the top of the heating coil housing. The...
Hello- The first thing to check, if you haven't already, is how well the dryer is venting. Make sure there are the flexible duct from the dryer to the wall is not crushed or crimped in any way. As well, with the dryer running, go outside and locate where the dryer exits the wall and feel how much air is coming out. Is should be blowing strong out of the vent. If not, and if the ducting travels a long distance through the walls you may want to have a duct cleaning service out. If there is a lot of lint build-up in the vent then the dryer will have trouble evacuating the hot air and the unit can overheat causing the thermostat to trip. If all your venting is ok but the thermostat is still tripping then replace the thermostat. Hope this helps, best regards.
Sep 27, 2010 | Bosch Axxis WTA 3510 Electric Dryer
The dryer will not produce heat and blowing lint
check where your dryer vent goes through your outside wall they sometimes clog up with lint and cause the escaping heat to recirculate back to your dryer causing the sensor to read the dryer as too hot clear all lint from the outside vent so you can feel the air coming out very steadily and quickly If this works you are all set otherwise check your heating element
Jan 04, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Where do I find the reset button on the Bosch WTA 3100 tumble dryer?
It would be at the rear of the machine. You need to remove the rear cover which is secured by Self-Tapping screws. Cover would be almost circular in shape and the button is in the position 10 o'clock looking from the rear.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 11, 2009 | Bosch Dryers
Drive Belt on BOSCH WTA 3003 dryer
No,It`s quite a difficult & fiddly job.
Nov 10, 2008 | Bosch Axxis WTA 3003 Electric Dryer
Bosch WTA4108 Dryer Not Heating
check and make sure you have 220 volts leving panel and @ the dryer motor runs on 110 volts takes 220 to heat
Oct 19, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Dryer venting
i think you will find that one of these caps should be off and preferably connected to a vent hose to go outside the house. the reason they are blowing off is that the air has nowhere to go
Jun 26, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Bosch condenser dryer
many bosch dryers are actually white knight. if there is a red reset stat on the back lhs then it is white knight! there is another stat close to the heater but out of sight when you take top off but you can see two grey wires going to it - make a note of where these wires connect, disconnect them and check continuity across them. there is also another stat towards the front. take of the back panel at bottom and you can see this stat in the air duct. check this stat as well. after that you are just left with the heater - check continuity across heater
Feb 02, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
521 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
