Question about Toshiba TEC B-572 Printer
Print jam on the thermal TEC B-572 TXP -3.5
When printing thermal tags on plastic rolled tag stock, I am continually getting the 'print jam' I follow the intructions to recalibrate, I re-load the stock, I turn off then back on the printer, I clear the que, it may clear and runa bit or I may have to re-do the processes several times. Either way the 'fix' never lasts long.
ALso-oothere is a new high pitched whirring sound as I print that didn't used to be there.
Also-I do not know what the forward and backward sensor knob on the bottom is for.
    Champion:
  • 254 Answers
The purpose of the knob if to change the position of the sensor. If you look at the sensor when turning the knob you'll find out that it moves forward (towards you) or backwards (away from you) This should allow you to place the sensor at the correct position. Further more, there are two holes on the plastic flag. the hole nearer to you is the transmissive sensor and the other is for reflective. Try to place the sensor at the correct position.
Posted on Sep 03, 2009
SOURCE:
Take up mandrel is not turning during print or feed.
check that you have selected thermal transfer in the dirver support option
Dec 20, 2012 | Toshiba TEC B-572 Printer
My toshiba TEC B-572 prints but it does not print evenly on each tree tag/label. it starts at the bottom of one and ends at the top on the last one. it stops cause it says that it is out of media. I...
Its not out of media, the issue is calbration, this printer will need to be physically serviced to have it work correctly again. Thisd out of media is a sensor that has malfuctioned and thus reporting this error to you.
I know I am probably telling you what you already know, but actually thisd item would need physical repair. if I get a zip code I can line you up with a Tech in your area.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 07, 2011 | Toshiba TEC B-572 Printer
I keep getting a Paper Jam message even after calibrating many times. Am using continuous roll of 1 X 4 lables. Was working fine until I tried to print another set of lables. What Gives? Am using a...
2 x possibilities.
1. sensor may need moving to to see label edge (green knob at RHS)
2. possible sensor faulty. Only testable by substitution.
Jul 06, 2011 | Toshiba TEC B-572 Printer
Printer printed 5 tags but there is wrinkles in the tags so i tried to realign the ribbon and now it will not print
Ribbon wrinkles are due to:
- Ribbon too large.
- Print Head misaligned.
- To much heat.
- innapropriate Transfer film.
check with your tag dealer
Apr 24, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
TEC B-572 printer, labels off center.
Check the alignement of the media guide. and the alignement of the print head. + X adjust parameter
May 15, 2010 | Toshiba TEC B-572 Printer
Hi, I can print to a TEC B-SX4 from a windows 2000 print server, but if I set the printer up on a windows 2003 server it goes offline and refuses to print. Same drivers Seagull 7.1.1.
this is due to continuous polling by the driver.
You must disable the bidirectional communication in the tools tag ,driver options, network parameters.
May 11, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
The 'eye' won't read the space between the labels,
recalibrate the sensors and check your label lengths and gap size
Mar 31, 2009 | Toshiba TEC B-472 Thermal Label Printer
You should recalibrate your sensor without or use reflective sensor instead of transmissive.
Jun 12, 2008 | Toshiba TEC B-572 Printer
Toshiba TEC B-572 Printer Logo
1,130 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
STEVE
Mia Talyor
Mia Talyor
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
