Question about APC Back-UPS XS900 (BX900) UPS System
Changing batteries The wires were taken off, single yellow, yellow/red...seperate but together, and a black. I know black is neg and red and yellow is pos. but nothing happens when i plug it in. Do you have diagram on what goes with what. or a manual on the xs 900?
  • 186 Answers
Black is ground
Posted on May 02, 2010
What colors are the Speaker Wired for a 1993 gmc 1500 van
    1. OK,GMC/GM are wired as such. White/Black wire, front left -[neg] White, front left +[pos]. Grey/Black wire, front rt -[neg], Grey wire, front rt +[pos]....Green/Black wire, left rear [neg], Green, left rear [pos]....Violet/,Black , Rt rear [neg],...Violet, Rt.rear [pos]........You will also have a Blue/Red wire that goes to antenna. ..A Blue wire for Power Remote....Red goes to IGNITION.....Yellow goes to Battery[for clock].....And finally a Black goes to Ground.......I hope that you have good luck and everything works out for you. `
Sep 07, 2015 | GMC Cars & Trucks
Trying to install kenwood kcd mp238 cd player into a 1996 Ford Expedition. I need to know wiring data to connect the wires of cd player to harness, which colors should I match wires up to, so I can just...
Black Ground, yellow, battery, red switch battery, blue not used, blue white power antennea/amp, brown tel mute, white black front left neg, white front left pos, gray black front right neg, gray front right pos, green black rear left neg, green rear left pos, purple black rear right neg, purple rear right pos
Oct 24, 2012 | Car Audio & Video
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
Wiring for 92 geo metro radio
  • Not sure if you are talking about wires from Metro harness or radio? Radios usually have red for power or hot, black is usually ground and yellow is probably the lights inside the radio. Try taking a VOM meter and verifying the wires if you know how to use one. red should be hot, black on ohms scale should conduct to the neg or ground. Yellow should have power (battery voltage) when you hit parking or headlights if I'm correct. If not may be the power antenna wire if it's from the radio, not used in most cases.
Sep 20, 2009 | 1990 Geo Metro
Pioneer DEH-P5800MP CD Player not powering on.
did you try the fuse behind the wireharness. if so check the yellow wire and the red one for power. also check if you have ground on it. if you want to make things simpler try to connect the black wire to the battery neg. and the yellow and red together on the positive of the battery and see if it turns on.
Sep 01, 2009 | Pioneer DEH-P5800MP CD Player
Pioneer AVIC-N3. What wires power it on??
the pioneer avic n3 has a seperate brain system and there is a cable that hooks the two together its called like the 13 pin wire or something and once you hook the brain and the head unit together it will have the display and everything else
May 25, 2009 | Pioneer AVIC-N2 Car DVD Player
8 wires on my subwoofer??
"One has positive and negative input, another positive and negative output (red and black on each)"
Just from your description, it sounds like pos/neg input are the 12 volt pos neg supply for the amp inside the subwoofer. Red is pos, black is neg.
"positive and negative output (red and black on each)"
This sounds like it's used if you want to proved 12 volt pos/neg to another component.
"and a third wire with left input right input positive and negative (blue, red, yellow and black)"
This is for the cables coming from the "subwoofer out" on the amp. This is 4 wires altogether -- correct?
May 08, 2009 | Audio Players & Recorders
What is the colours for the wiring system for subaru legacy 94 for the amount of 14 wire's
http://www.the12volt.com/installbay/stereodetail/1981.html
above is link to wiring for 94 legacy , yet another source has a different layout , make sure the colors match your vehicle , 2 sources provided .
yellow/red = hot in on - fuse 17 -15amp
green = interior lights
blue/red = hot all times , fuse 25 - 10 amp
black = ground
yellow/blue = interior lights
black/green = power ant.
red/yellow = right fr neg
brown/white = left fr neg
white/red = left rear neg
blue/yellow = right rear neg
white/black = right fr pos
green - left fr pos
red/black = left rear pos
red/white = right rear pos
Jan 01, 2009 | Car Audio & Video
Re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Apr 19, 2008 | Car Audio & Video
APC Back-UPS XS900 (BX900) UPS System Logo
145 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
