Question about Troy Garden
AFTER DOING THE RECOMMEND STARTING STEPS, MY STRING TRIMMER SPUTTERS AND DIES, IT DOES THIS SEVERAL TIMES BEFORE IT WILL RUN. THE LAST TIME TRYING TO START IT THE SAME THING HAPPENED BUT THIS TIME IT NEVER DID RUN. IT IS A TROY BILT MODEL.
  • 64 Answers
Either the carburetor is dirty, not set right or the control lever inside that lets the fuel in isn't set right.
Posted on May 04, 2010
Hi there problem with new black and decker 34V string trimmer
Generally all portable tool batteries slide into position until a click is heard alerting us that it is locked in position & just wont come falling out in use, look @ the manually closely & follow the steps ( you'll get it! ALSO note there will also be a way to release the battery once you have charge it......Good luck :)
May 26, 2014 | Black & Decker String Trimmer Cordless 12"...
Echo SRM 200 series trimmer is great. I noticed though this summer once I reel in the new string, a short time of trimming later, only 1 side of the string appears. When I open up the reel, the string is...
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
Jul 02, 2011 | Echo Rapid Loader, Trimmer Head
My battery will not keep a charge it don't last 10 minutes/ i like the weedeater but it just don't last long enouh
I had one of these a while ago, the batteries are just cheap. Trimmers also use a lot of energy and battery powered ones aren't the best way to go if you want them to run a long time. I highly recommend replacing it with a good gas or plug in model from your local hardware store, they can help you find the right one to fit your budget. If you don't want to get a new trimmer you are going to be fighting dying batteries every year.
Jun 06, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Worx trimmer works for 5 minutes then dies
The battery is dead, Worx contracted with a cheap battery manufacturer, you can buy replacements on ebay, but they will fail quickly too. I recommend getting a new trimmer unless you want to buy new batteries every year.
Jun 05, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Only used my trimmer 5 times since I had, trimmed my hedges 2 times last year & twice this year. After done doing my hedges, I put on my weed trimmer when finished & holding my trimmer in idle it...
Some disassembly may be required to get to the starter/recoil unit to fix this. The unit has Torx head fasteners and some level of mechanical skill is involved. Check your warranty?
Aug 13, 2010 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Starts fine but when u close choke and give gas,the engine dies
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 24, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Trimmer won't run - B&D CST2000
could be loose connection in the motor due to vibration.
Jul 07, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
74 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
