Question about LG LHD45EL Dehumidifier
The condenser does not work
The condensor does not work
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 02, 2010
My dehumidiyer fan runs, condensor seems to work but the coils do not get cold so thus no condensation. what can i do to get my humidiyer working?
typical for most brands of dehumidifiers.after 2-3 years use the refrigerant/freon leaks out and they wont cool,you can have it recharged,but quite expensive as i charge between $50.00 to $75.00 to do this
Aug 07, 2011 | Whirlpool AD40DSR Dehumidifier
The fan runs, but no water condenses. It seems like the condensor does not run. Is this death to the unit?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 08, 2011 | Whirlpool AD50USS Dehumidifier
My model LG3850A20500H dehumidifer is not collecting any water but is running. Is there anything I can check?
You can check the condenser unit, by touching it. (be carefull of hot surface) if the condensor unit not warm at all we can sure that the dehumidifier is not working, (only fan). The problem may be come from compressor or temperatur limit is not working or cooling agent is finished cause by some leakage on the tube.
Aug 12, 2009 | Dehumidifiers
LG LD65EL Dehumidifier doesn't work properly
What do you have the humidity level set at on your dehumidifier? The average is 65%. Make sure you do not have it set at 75% because if you do this could be causing it to keep the humidity so high.
Jul 02, 2008 | LG LD65EL Dehumidifier
Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Jun 02, 2008 | Goldstar DH5010B Dehumidifier
No 120v to fan motor
It sounds as if this may have electronic controls on it. If so, the problem could be related to too low of an ambient temperature or too low humidity in the air. If this design has a temperature sensor built into it, you may be experiencing "hibernation mode", where the unit will appear to be dead, when it is actually awaiting the proper temperature to employ itself.
The following statement is a parameter for all dehumidifiers and some of the control issues may vary, but the theory is the same.
Dave E. (Illeagle)
Jun 02, 2008 | Kenmore 54351 Dehumidifier
Friedrich dehumidifier
Dave E. (Illeagle)
Jun 01, 2008 | Friedrich D50C Dehumidifier
Ebac 880 E
If your model does not employ a "Frost-Guard" the condition you describe will avail itself when the above parameters are not met.
Simply unplug, or turn off the unit, until the above parameters are met or exceeded.
Dave E. (Illeagle)
Jun 01, 2008 | Ebac AD850 Dehumidifier
Kenmore Dehumidifier won't turn on
Dave E. (Illeagle)
May 13, 2008 | Dehumidifiers
D50c
Dave E. (Illeagle)
Aug 10, 2007 | Friedrich D50C Dehumidifier
LG LHD45EL Dehumidifier Logo
51 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
