Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a troybilt tuffy. The drive belt started smoking and no longer goes forward or reverse. Blades still work fine. What could be the problem? I've checked everything. The belt is on fine, it engages and starts burning in the front. Is something locked up in the back? How can I check?
  • wheelercha May 02, 2010
    Okay - I lifted it up and in with it in nuetral - one wheel spins backward and one forward. I put it in drive and the same thing. In either case, I could barely turn the pulley connected to the transmission after using all my strength. What next?
    I don't know if that last message posted. But, aafter jacking it up, in neutral one back tire spins forward and the other in reverse. I tried to turn the transmission pulley and it wouldn't budge. I tried to put it in drive and it doesn't seem to be going because both wheels spin -one backword and one forward (like it did in neutral.
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. If the belt was smoking then it is probably shot and will need to be replaced. The problem is going to have to be investigated as to why he belt started smoking in the first place. Before putting then new belt on I would try turning the pulley on the transmission before putting the belt on to see if the transmission turns freely.
Posted on May 03, 2010
    Guru:
  • 416 Answers
Sounds like you are on the right track. Block the rearend up and try to rotate that tranmission pully by hand.
Posted on May 02, 2010
  • Adam Halfhill
    Adam Halfhill May 03, 2010
    At first, I would think the bearing for the pulley is locked up. If you can spin the wheels in neutral and the pulley still doesn’t turn, I’m going to have to go with my first impression. Either your bearing rusted and your pulley is seized or you have some damage in the gear box. Either case, your drive transmission needs serviced. If you know of a lawn tractor servicer, you should give them a call and see if they can locate a used or new transmission for you or repair yours. Changing it yourself wouldn’t be too bad, trying to repair the old one could turn into a nightmare. If it were me, I would pull the gear box out and try to soak the spindle bearing with penetrating oil over night, then try to turn it. Don’t put too much pressure on it… you don’t want to cause more damage if you are planning on having it repaired. Best wishes, I hope this was helpful.
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Craftsman 20.5hp briggs and stratton will not go forward or reverse when I let off the clutch it starts to squeal and smokes fronm the drive belt
could be as simple as a worn out belt but look to see if there is a oil leak getting onto the belt
May 04, 2012 | Garden
I have a Craftsman DYS 4500 that the will not go forward or reverse. It cranks fine and the blades will engage but when you shift it in either forward or reverse nothing happens. It was working fine the...
did you have a back wheel off if so make sure the key way is in place it sits in the grove of the axle and the rim its about 1/4"x1/4" x 2" long if this is missing you will have no drive also if its a auto trans check your buypass lever hope this helps
Sep 06, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
Tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do i adjust belt on troy bilt horse tiller
How do I tighten a belt on a troybilt Tecumseh rear tine tiller?
May 04, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
No power when drive is engaged
Hi
Check your drive belt and the tensioner pulley that holds tension on the drive belt. Its possible for the tensioner pulley to be sticking and not putting enough pressure on the drive belt causing it to slip.
Grab hold of that tensioner pully and make sure it moves in and out freely against the drive belt.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
81 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
