Question about Janome Memory Craft 9000 Computerized Sewing Machine
My Memory Craft sews great until I start to quilt or use one of the different stitches and then the stitches either skip or become so tiney I can't pick them out.
    Genius:
  • 1,116 Answers
Skipping could indicate you need to use a larger size needle.
Tiny stitches could be save reason, or the top thread is hanging up.
Sometimes the thread can wrap around the spool pin or catch on a rough surface on the end of the spool.
Be sure to use the correct size spool cap and if the thread is wrapping around the pin, a thread net can help.
Give the machine a cleaning according to the maintenance section of the manual for your machine, including cleaning the feed dogs, bobbin case, shuttle and surrounding area.
Make sure the feed dogs are up unless you are free motion quilting and the presser foot down.
This may seem elementary.........just trying to cover all the bases.
Posted on May 02, 2010
When quilting on the janome memory craft 8900 QCP. With walking foot and quilt bar stitches all at once became very tight Had to all at once adjust stitches
The thread could be snagging in the thread path. Remove the thread from the machine and rethread from the beginning (be sure to ALWAYS RAISE the presser foot when threading!). When I've experience this issue, the thread has usually been looped around a thread guide or the thread spool.,
Oct 13, 2017 | Janome Sewing Machines
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
Oct 08, 2014 | Juki DDL-8700 Industrial Straight Stitch...
I want a longer straight stitch (mine only goes up to 5) on Janome MC 4900, to mimic hand quilting look.
There are several models of machines that do a longer stitch, usually called a basting stitch. Unfortunately, your machine does not have this function. If you are looking for a machine that will give you a hand quilted look, the Baby Lock Sashiko can give you that, though it doesn't do anything else.
Feb 26, 2014 | Janome Memory Craft 4900QC Mechanical...
Open-toe darning foot skips all stitches....help!
Hmm, have you installed a brand new needle? Make sure the needle is compatible with the thread and fabric. Sometimes a top stitch or microtex needle will work better for free motion quilting or darning.
https://www.superiorthreads.com/education/what-causes-skipped-stitches
https://moonlightingquilts.wordpress.com/2012/04/19/skipping-the-skipped-stitches-in-your-free-motion-quilting/
https://www.generations-quilt-patterns.com/skipped-stitches-driving-you-nuts1.html
Feb 26, 2018 | Kenmore Sewing Machines
My machine is skipping stitches
Lower the pressure on the feed dogs, use a stretch stitch, and longer stitch length. Be sure to use a good quality thread, and maybe go lighter weight thread.
Oct 25, 2017 | Janome Memory Craft 9000 Computerized...
I have a Janome Memory Craft 3000 sewing machine. It suddenly started skipping stitches. Now, after cleaning out the lint as well as I could, the machine will not pull the bobbin thread up. Any ideas?
Good day!!!
please apply a some oil on the motor and other moving parts inside you sewing machine..
After that reboot the machine and used it....first try is persisted but when you used it continuously for at least 10 minutes your machine is OK...
Jun 28, 2011 | Janome Memory Craft 3000
How do I quilt on my 9000
Your question is a little vague... Put simply, here is how to make a quilt. Start by putting 2 pieces of material (good sides together) and sew a 1/4 inch seam. Keep on adding pieces until you have a quilt.
Apr 07, 2010 | Janome Memory Craft 9000 Computerized...
Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Apr 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Janome Memory Craft 9000 Computerized Sewing Machine Logo
160 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
