Question about Kitchen Ranges
The oven is fairly old and the probe has been bent for years. It gets in the way and is never used, a real nuisance. I got frustrated and took pruning shears and cut the damn thing off.:) It just dawned on me that it may not have been a good idea. Have I made the overn dangerous? Was there electric power in that probe. There seemed to be a puff of something after I made the cut. I know it was dumb but have I caused a dangerous situation?
  • andyabels May 02, 2010
    Sorry but my most basic question is... is it dangerous? Can I continue to use the oven as is?
    Thanks you told me what I want to know. Am I correct I need to have a service professional come in?
  • 10,319 Answers
I assume you have an electric oven. The probe is a heat sensor. If not used for the oven remove the heating element to the oven as well to safeguard your home. If this is a gas oven disconnect the electrical wires to the oven timer or shut the ovens valve to the off position
Posted on May 02, 2010
  • frank thomas wilson
    frank thomas wilson May 02, 2010
    You can not use the oven with the probe cut off
    Yes & have it replaced if you can not do it yourself
Oven heats extremely slowly - gets to 250 after 45 minutes. Oven is 5 years old. What do I need to look at?
the most common cause is a bad oven temp probe replace the probe if the problem continues then you may eed to replace the electronic control board.
Jan 30, 2011 | Maytag Ovens
Oven heats to 325 when set to 350 the door seems like it doesnt close all the way. Can I adjust the door or is there a way to calibrate the temp. Do I need to clean or replace the temp probe?
Hello - The solution is simple, but a little expensive to fix. The door hinges are bent. There is no way to fix them- they are stamped steel and can't be un-bent. A pair is about 75$. There are four screws holding each one on and are fairly easy to replace.  After replacing hinges, the door will pull shut and hold in heat.  Provide complete model number from tag on oven when getting parts.        Remember- Don't use 'self-clean', or 'self-destruct' as most techs call it!        Please acknowledge this posted solution if helpful.  Have more info if needed.  Thanks-  Ed
Mar 24, 2010 | KitchenAid KEBC107 Electric Single Oven
Our CTO650 toaster oven dosn't toast, but the oven works fine. How do I get into it, and can this problem be fixed?
I called the 800 number on the instructions (800-231-9786),. I suffered through a confusing phone tree AND a 10 minute wait on hold. I was told that my 3 year old toaster oven is "fairly old" and that parts are no longer made for it.
Very frustrating. I expect a toaster over 1) to work and 2) to have parts available for 10 years after I purchase it. The ideas of a toaster oven as a "consumable" has terrible implications for our environment.
Feb 01, 2010 | Black & Decker CTO650 1500 Watts Toaster...
How to replace a front right strut on a 94 probe
You have to rent a spring conpresser tool. You can buy one but try to search for a place that rents them. Good luck!
Nov 05, 2009 | 1994 Ford Probe
Oven not heating
check the ignitors, sounds like you have to replace them
Jul 15, 2009 | Whirlpool Ovens
Probe and sensors sticking too far out
Yes the probes can stick out from the back oven walls. They look like thin pencils about 6" long. They should NOT be loose. The probes are your temperature sensors. If they become damaged your oven may not work. The probes are generally high up on the wall and to one side...about an inch or so down from the top...and the same from the side. They should be horizontal and not bent at an angle. Some probes run along the side of the oven wall and do not protrude into the baking area. In general the probes (whatever type) should not really interfere with the baking zone
Sep 13, 2017 | GE JKP27 Electric Double Oven
KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Dec 10, 2007 | KitchenAid KGRC608LSS Gas Kitchen Range
DOUBLE OVENS FROM KITCHENAID
Redhead Do nothing and call the manufacturer. Your oven has one year warranty. Gendos...post back
Mar 22, 2007 | KitchenAid Architect Series KEBC278KSS...
F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Mar 04, 2007 | GE JTP15 Electric Single Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
