Hi i need to set up my Linksys here is the problem
It has a network password ect.. that we are not able to get to so how do i reset the system and then how do i get set it up i have never set up this system before so please explain well this system is used for a computer with out wirless and a laptop with wireless connection we would like both to work.i will aperciate your help thanks info for wireless is
2.4 ghz 802.11 broadband router with 4 port switch its a linksys wireless b model #BEFW1154 ver4 it will not let me put it down there so i made that up k
  • witness705 Mar 26, 2008
    thank you very much this worked i apperciate your help
    thank you very much
    Scholar:
  • 89 Answers
Hello, On back of router there is a reset button. Use paperclip or equivalent and push in for 10-15 seconds. This will reset router to default. Cables are connected in this order. Phone line to DSL modem, to Router to Computer. Bring up browser and enter this address in address window: 192.168.1.1 this will bring up a username and password window. Enter admin for the username and leave password blank, hit enter and this will let you into the router settings. There will be different setting options like enable broadcast, WEP or WPA security. You can also change SSID and username and password. The DHCP box should be checked so it will assign IP address dynamically(Automatically). If there is anymore info please let me know. Hope this helps.
Posted on Mar 25, 2008
  • Anonymous Mar 26, 2008
    Great, glad to help, If you would rate this as a FixYa..Thanks,
    Genius:
  • 3,587 Answers
You'll need to speak to linksys tech support to guide you on resetting that router..
6ya staff
SOURCE:
Forgot user name and password need to add new
Sorry but this is the only to reset the password
Press the Reset Button for approximately 10 seconds
Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
Jun 06, 2011 | Linksys Wireless-G WRT54G Router
I have no wepkey to network the problem is anyone can browse connecting to my network using wi-fi
  • If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
    To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
    Once your router is hard reset, you will need to login and reconfigure it again.
    To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
    LinkSys Default Password
    On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
    Once you are past the login screen, you are able to reconfigure the LinkSys router.
    You want to go to the management tab and change the administrator password to something else to keep others from accessing your router.
  • 3
    After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
    Good luck
  • Mar 12, 2011 | Linksys Wireless-G Broadband Router
    I need to secure the network from my router ....how do i do this?
  • To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
  • After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
  • Oct 11, 2010 | Linksys Wireless-G Broadband Router
    Lost my password and cannot connect new netbook
    hi
  • Step 2reset-password-linksys-router-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a02/2p/6m/reset-password-linksys-router-1.2-800X800.jpg'); }); Once your router is hard reset, you will need to login and reconfigure it again.
  • Step 3 After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
  • Jul 21, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
    Lost my pass word wireless router linksys by cisco
    Are you looking for the wireless password or the password of the router?
    If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
    If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
    Click here for more information about the routers and wireless network.
    Apr 23, 2010 | Linksys Wireless-G Broadband Router
    I have a linksys router and my IP address is 192.168.1.1 how can I locate my passowrd/WEP?
    The Linksys configuration URL is http://192.168.1.1 and if you cannot Login or remember the password then you can reset the router back to the factory defaults by -
    Power up the Linksys and pressing and holding the pinhole reset button at the back of the Linksys for 30 secs. The router will restart.
    Username Login = admin
    Password = admin
    You can now change the admin password and configure the wireless settings ie SSID, WPA or WPA2 encryption etc.
    Don't forget to configure the wireless card in your computer with the router's wireless dettings so the computer can connect to the Linksys.
    Apr 04, 2010 | Linksys Wireless-G Broadband Router
    How do I reset the password on a linksys 200
    Hold the reset key down with power on for 15 seconds.
    In addition, there's an error in some copies of the user manual, the correct login is:
    username: admin
    password: admin
    hope this helps if can help further let me know
    Oct 29, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
    I forgot my password
    Sep 08, 2009 | Linksys Wireless-G WRT54G Router
    Linksys router G - buddy forgot password I am at my brother-in-laws home for the week and they don't know the username and password for the linksys but they do have custom settings. How can I just reset...
    Jul 01, 2009 | Linksys Wireless-G WRT54GS Router...
    Password problem
    On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." Once you are past the login screen, you are able to reconfigure the LinkSys router
    Aug 10, 2007 | Linksys NSS4000
    Open Questions:
    how to reset aol password @{18OO~8O31O69} phone number There are two circumstances that can cause someone to want to change his/her AOL password: 1 forgetting the AOL password and needing to recover it and 2 to change the AOL password. The latter can be because the AOL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's AOL password at least once in a month. Contact Aol Mail Password Reset 1-8OO-8O3-IO69 . For your convenience to contact Aol Mail Password Reset We have provided all possible information of Aol Mail Password Reset. You can contact Aol Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an AOL Password The following steps show in detail how to change an AOL password when the current password is known: Sign into the AOL Mail Account from AOL Do you want to recover/reset your AOL email password? So you'll be do the some steps to recover your AOL password. We'll help you to fix your problem and we'll guiding the some steps to recover your AOL password. Follow and do the below steps to recover your AOL email password- Go to the AOL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your AOL mail message on your Gmail account. AOL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While AOL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, AOL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your AOL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your AOL password.
    Oct 23, 2019 | AOL Computers & Internet
    Computers & Internet Logo
    233 people viewed this question
    Ekse
    Marvin
    Marvin
