Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Engine won't stay running
I actually have the smaller 17.5 hp single-cylinder version of this motor. It's mounted to a lawn tractor (Troy). Was cutting grass and engine just died. Checked all the usual, spark, fuel, compression. Spark is good and strong, compression is fine, fuel getting to carb. What I think is the problem relates to what looks like a small solenoid on the bottom of the float bowl with a 2-wire plug attached to it. I suspect that this is some kind of low-oil shutdown circuit. Checked oil level, and oil it is full.
Engine will start if fuel is poured into carb, but will not stay running. Tried disconnecting plug from solenoid, but still doesn't start. Seems no fuel is getting to engine, as the plug is dry.
Thoughts on how to troubleshoot this thing further? How does that circuit work? It looks like one wire is just a ground going to the block. I guess the sensor could have failed or possibly the oil pump (do these things have oil pumps?) went.
  • 10,319 Answers
Check the fuses which are under the seat
Also it will not run unless the parking brake is set when your not setting on the seat
Posted on May 02, 2010
    Brigadier General:
  • 4,088 Answers
The carburetor solenoid has nothing to do with the low-oil-pressure-switch (which kills the ignition when it has low pressure oil). The solenoid requires power from the battery through the ignition switch to open the main jet that it plugs when off. If the solenoid has two wires, one goes to the battery and the other to ground. Testing is simple--turn on the ignition and check for 12 volts across the solenoid connectors. If it has voltage, the solenoid may be open circuited (new solenoid), or the plunger inside of it is stuck in the plug-jet position (which may be cleanable). Hope this helps!
Posted on Jun 07, 2010
I have a charging problem with JD L155c lawn tractor. The battery is new and the voltage to the battery is 12 volts. Not enough to charge the battery. How do I check the ac voltage & what should the...
There are several possible Mowers of the "L" 155 versions.
John Deere LA155 garden tractor lawn mower. These stopped being made in 2010 (they started production in 2009, and so enjoyed a run of 2 years on the assembly lines). The JD LA155 is powered by a Briggs and Stratton 2 cylinder, V twin engine. This engine is 0.656 liters (40 cubic inches) in size and produces 22 hp.
1998 - 2001 LT Series
John Deere LT155 Engine: Kohler 1-cyl gasoline
2006-2006 L155c, This series was produced only in 2006.
Briggs & Stratton gasoline, 2-cylinder air-cooled, 724 cc [44.2ci ], 25 hp
Model 445777-0168E Code 021125YC, these are the engine numbers from a 25 hp twin cylinder, B&S.
Notes on these engines from parts supplier ereplacementparts.com:
Briggs and Stratton 445777-0231-E1 Engine: The proper flywheel part number and/or the alternator magnet size will determine the alternator type or output.
This 25 hp engine has 3 different possible alternators, standard circuit, dual circuit, tri-circuit. I would need the exact engine model numbers in order to precisely answer your question. Often mower models have choices for the engine they come with. In this situation the engine model is more important than the model of the mower.
Testing an alternator is fairly simple; all you need is a multimeter for testing.
  1. Disconnect connector from stator.
  2. Set multimeter for AC volts.
  3. Attach RED test lead to either pin on stator side of stator connector. (On single wire leads, attach RED test lead to the single pin.)
  4. On two wire lead models, attach Black test lead to the other pin. On single wire stator connectors attach the Black test lead to the engine ground.
  5. Prepare the lawn tractor for engine start (set parking brake, blade off, etc). Start engine and run at full throttle.
  6. Check output. Output for engines of this general size run in the 30 to 50 volt range. For instance the B&S V twin 22 hp AC output at full throttle is 30 Volts minimum. Other B&S on these machines spec 40 Volt minimum.
If your voltages are not in the manufacturers range, or non-existent, your stator is partly shorted or completely burnt out (open circuit). Either way you have to replace it.
A. In the picture is a single lead stator connector.
B. In the picture is a two wire stator connector.
Mar 15, 2015 | Garden
Intek 500cc 19.5 hp 1 cylinder, runs well, but difficult to start even with a fully charged battery
based on the symptoms you describe I would eliminate mechanical issues including the starter. I would focus on the electrical - particularly making sure all your wiring has good connections including the grounds. in particular look for voltage drops on your positive (+) connection to your starter and ground, and then also check for any unusual resistance (ohms) in the wires themselves.
Jul 28, 2014 | Briggs AND Stratton Intek Briggs &...
Won't start, apparently due to low compression. Any easy solution besides replacement?
First verify the compression is below say 90-100psi. A four stroke engine will run on compression technically as low as 70psi, but will dog for power under load. It depends what kid of engine it is, if it's an "L" head which is a single cylinder engine, it should be very easy for someone mechanically inclined to replace the head gasket. I doubt there is enough piston ring wear in something that new.
May 20, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
What engine other original will fit in mower?
Nearly any single or twin cylinder engine with the same configuration (ie. vertical shaft) will fit under the hood of a craftsman that used to run 20 HP.
Jul 26, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
May 30, 2011 | Troy Garden
I was engaging the blade on my 17 hp craftsman lawn tractor and the engine died. Now the engine won't turn over. ???
the motor wount turn over if in fact the belt is tight around the motor pully. remove the deck belt then also make sure there are no switches not working.
Nov 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Troy Built 6605 lawn tractor. The engine
check your belt might be off a pully or maby your spring is off
Nov 09, 2009 | Garden
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Canaballing parts
Hello tim38663:
Depending on the Engine Model and Spec this Tecumseh Usually has the Same External Parts as a 15 HP to the 18 HP Single Cylinder Tecumseh Engines.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
988 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Bill Boyd
Daryl Gleaton
obsteiner
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
