Question about Hotpoint WMA40 Front Load Washer
How do i replace drum berings on a hotpoint wma40,and aprox.cost thank you
    President:
  • 2,468 Answers
The bearings are about $20,the lip-seal to protect the bearings from water is about $45,and if you hire it done you need to find out the labor rates in your area,it can take from 2-7 hours to complete depending on how hard the old water soaked and rusted bearings come out of the bore
Posted on May 02, 2010
Testimonial: "thank you for your help."
Hotpoint wma40
hi take the band of rubber just inside door take soap draw out take screws out holding panel this comes of dont pull wires of control panel or mark were they go take kick plate off you have screws holding bottom of panel top ones are under top panel take two screws holding catch out were door clips in push panel up you can get to front of drum to take off takes about 15 min oh sorry top off 1st hope this helps
Jan 29, 2014 | Hotpoint WMA40 Front Load Washer
Hotpoint WMA40 washing machine is leaking from detergent drawer- any suggestions ? Thanks
Hotpoint WMA40 washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 27, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint washer
common problems with timer which work like a clock and goes though the cycle, bad timer will cause it not to go through its cycle. it very cheap and easy to replace everything is all plug in.
Nov 14, 2009 | Hotpoint WMA40 Front Load Washer
Brocken door spring
If you have not rectified your problem, you need to seperate the 2 door halves by removing all screws securing the 2 halves, and prize`appart, then you can easily change the spring.
Please rate my solution.
Thanks.
Oct 05, 2009 | Hotpoint WMA40 Front Load Washer
Drum not turning
If it fills and pump works, then it can only be the motor or module, there is no sure way of determining which it is without trying to fix it with new parts.
You can look at the module to see if it has blown a track, if it has, then the moor has caused the prob.
Thanks.
Jul 21, 2009 | Hotpoint WMA40 Front Load Washer
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
REFITTING THE BELT ON HOTPOINT WMA 40
Place it on the motor pulley and then guide it around the drum pulley. It will have come off for a reason which if you do not correct will cause it to come off again. Lay it flat on a table - if it does not lay flat - replace it. Check the pulley on the drum does not move from side to side. (problem with pulley or drum bearings)
Sep 03, 2008 | Hotpoint WMA40 Front Load Washer
Very noisy
The washer is not a sealed unit but the rear drum bearing are also you will need a new spider...To take a look inside - Initially you will see enough from the top to see where things are...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel.
If the Drum bearing has failed it is usually due to over loading or a faulty seal in the drum, water leaks into the inner bearing. This causes corrosion and then ultimately failure.
In the likely event that the bearings have failed (I have had a hotpoint wma33 fail at 23 months...) Its actually cheaper for you to pay hotpoint to fit a new drum (Parts are free for 5 years! you just pay a flat callout fee - believe me its a bargin). + they never ever replacing just bearings, it takes too long for them. They will do a whole drum and spider arrangement in under 2 hours...
I wasted 3 days because these things are really awkward to remove and refit. The callout fee for a hotpoint engineer a fixed cost. I bought a spider see:
http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=954798&brand=&model=wma33&part=spider
This spider costs 61.25 + delivery - ouch.
I bough a half drum thinking I would keep the costs down. Hotpoint will fit half a drum or full drum (Depending on what is on the van for their call out fee) the actual cost of a half drum is 75.99 + delivery see: http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=639770&brand=&model=wma33&part=drum
and a full drum costs 161.49 + delivery
see: http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=639763&brand=&model=wma33&part=drum
They take away all the rubbish at the end also!
I know this site is about doing it yourself and I can go into more details about how to do it. But because I did not have the correct tools that hotpoint must have to pull the bearings from the housing etc - I feel I would be wasting your time.
I hope this helps
Please don't rate me as unhelpful, this is not a simple change the bearings task.
Jul 06, 2008 | Hotpoint WMA40 Front Load Washer
Hotpoint WMA40 Front Load Washer Logo
314 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
