I have an American Standard Freedom-80 Two stage furnace/AC. After replacing my old Honeywell with a new Honeywell RTH2310 thermostat (which the guy from A-1 Heating & A/C assured me was compatible with my system) the A/C won't kick on. The thermostat is registering the ambient temp & when I turn the thermostat fan switch to ''on'', the fan turns on, but not with cold air. I have not even tried the heat because it was 89 degrees F inside already, but would expect the same issue. The metal door on the furnace has a peephole, through which I can see a blinking red light. Should that light be solid red, or is it supposed to be blinking? Is it likely that I just need to re-check the wiring connections on the thermostat? Or was the A-1 guy incorrect about the compatibility of the thermostat? Thanks, Amanda
  • 1 more comment
  • aef222 May 02, 2010
    Yes, I failed to mention that of course I do have the thermostat set to the "cool" position...
    The blinking light is on the actual furnace, not the thermostat and when I take the cover off, the only information I see near or pertaining to the blinking red light is "DS1", which means nothing to me.
    Would the normal situation be for the light to be solid red, or off, or does it depend on the furnace?
  • Brian Niten May 11, 2010
    If you put the fan switch in "on" only the fan will come on. It is a manual control for the fan. You have to put it in cool to get the A/C to work. Have you tried that? Also if you look at the owners manual or remove the cover with the peep hole so you can see the circuit board it should say what the blinking light means whether it is an error code or normal.
If your system worked prior to installing the new thermostat, then you may have to change how your thermostat is wired in the rear, as I encountered the exact same problem in that regard. Beyond that, if you have a blinking light, chances are it may be a problem with the furnace itself. After you are confident the thermostat is wired properly, if you still get a flashing light, then you have an internal problem with the furnace and will have to get a repairman out to investigate the code given by the flashing light.
Posted on Jun 08, 2010
  • 674 Answers
The DS1 probably means dip switch 1. The light is used to give you different trouble codes. There should be something printed on the circuit board or on a label nearby that lets you know what each series of blinks means. I agree a good place to start would be to recheck the wiring then make sure you have the program in the thermostat right. It has several options.
Posted on May 02, 2010
  • Brian Niten May 02, 2010
    I think blinking would be normal.
5amp fuse keeps blowing
I would disconnect the compressor contactor,set thermostats to cooling mode(tape off low voltage wire] to restart.You may also disconnect REV valve low voltage wire.If fuse blow it may be the thermostat or the defrost board.If fuse blow this time remove thermostat and hard wire at wall,at this point you will locate the short.Once you locate the problem rewire control back into circuit and retest with out that bad part.
Jun 28, 2018 | American Standard Heating & Cooling
American Standard Freedom 80 single stage fires up... runs and blows heat for a few minutes then shuts off but then 5 minutes later it repeats the cycle. Any ideas? I have replaced the filter.
A 5 min run time tells me that it is overheating. Probably a dirty evaporator coil, or a loss of airflow due to blower issues. Or even a high temp safety that is opening prematurely? Tstat is calling for heat so its doing its job. It could be overheating or a fault at any of the components in the furnace. 90 percent of the time its a dirty blower wheel, EV. coil, or a missing filter that's so dirty its cutting off the airflow. Hope this helps!
Mar 01, 2017 | American Standard Heating & Cooling
Wiring Honeywell 9580 to old furnace with no C wire
This is not going to be easy. Check the wiring in the wall to look for the third wire. If they did not run one, you have to run new wire to the furnace and thermostat. If they stapled that wire to the walls inside studs, then it is going to be even harder to run the new wire. Once you run that new wire then you have to locate the connection in the furnace that has the common (c) wire for the transformer. Check you tube to see if the have any how to video.
Oct 13, 2015 | Honeywell RTH8580WF WiFi Thermostat
I am trying to install a thermostat and I am not sure where to put all the wires... it is for american standard freedom 90 two stage - furnace and air conditioning
Should be like this:
Y from furnace goes to Y on thermostat (yellow)
C from furnace goes to C on thermostat (usually blue)
G from furnace goes to G on thermostat (green)
W1 (first stage heat) to w1 on thermostat(white)
w2 (second stage heat) to w2 on thermostat (black)
Doesn't sound like you have a heat pump but if you do "o" will also have to be connected which is the reversing valve.
Jun 21, 2011 | Heating & Cooling
How doI replace the motherboard on a American Standard Freedom 80?
Hello, to replace the intergrated control board on your furnace you need to turn off main power to your furnace, then label the wires so you will know where they go on the new board. Then just take the old board to a hvac supply store and they will give you a replacement and just connect the wires to it and turn on Furnace.
Mar 02, 2011 | Heating & Cooling
I have red, yellow, green, blue wires. How do I wire to a RTH2310?
red is hot 24v goes to r terminal, yellow is for ac and goes to y terminal green is for the blower motor and goes to green terminal, blue can be a common or 2nd stage heat or 2nd stage cool or humidifier is blue connected on the furnace? If so what terminal?
Dec 14, 2010 | Honeywell Electronic Programmable...
Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Jan 25, 2009 | Honeywell Electronic Programmable...
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
2,525 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
