Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Clutch slipping? The chain spins fine and the motor runs great but whenever I try to cut the chain stops and it like the clutch is slipping. Can you adjust the clutch or does it require a new one. Also the bar oil just seems to ooze out now. My carrier box was full of bar oil. Thanks Wes
    President:
  • 2,220 Answers
These are related. On your saw the oiler only supplies oil when the clutch turns, and I am going to ignore the oil problem. If it does not oil after clutch replacement please post back. The oil pump is inboard behind the clutch Please inspect it and the worm gear before reassembly.
A link to an "IPL, 455 Rancher, 455 e, 460, 2009-10, Chain Saw" follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HIUS/HIUS2009/HIUS2009_70.pdf
The clutch face is on item 1. Inspect the drum (item 3) for glazing. If extreme it may require replacement too. There is also a bearing (item 4) that might effect both problems I suggest you replace it as part of the clutch repair. These parts may be available at your local Husky dealer, if so it will save time and shipping cost. Showing him your parts might be a good idea too.
This is helpful with clutch removal.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If the link I provided is not your saw you can find yours here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 02, 2010
    Brigadier General:
  • 4,088 Answers
Probably, the interior of the clutch was soaked with oil. Try washing it out with spray carburetor cleaner by removing the cover, chain, and bar. Unless the clutch surfaces were burned from any slipping that occurred, that should restore the clutch. When reassembling, make sure you can move the tightened chain by hand. Check for proper oiling, by running the bar tip at speed in front of a piece of cardboard for several moments-- it should throw off a thin line of oil. Hope this helps!
I have a Remington electric versa saw rm1635w and the chain won't spin around the bar what do I need to get it running again
there is a safety clutch that you disengage when finishing the cut
it disengages the chain from the motor drive by a dog clutch
pull the safety bar back towards the trigger and the chain will cut
if you leave the finger on the trigger and the chain jams in the cut , you push the bar forward and the motor spins free
if that doesn't work take it in for a fix as that clutch is failed
Nov 16, 2016 | Remington Garden
WEN 6014: Motor is running, but chain doesn't move. Chain sprocket seems fine, cogs are only slightly worn, sprocket fits perfectly, no wear. Is there an internal clutch or connector? Motor worn out?
There is a clutch behind the metal housing where the chain sprocket at the engine end attaches to the chain . There are wear parts with springs on them that have to be changed. ChainSaw Shed Chain Saw Parts for Wen Wagner Brand Chain Saws Chains Bars... You can get parts here.
Sep 15, 2016 | Garden
Chainsaw runs fine but the blade slows down to stop when i cut
too much load (too large a cut), dull chain, no lubrication oil on chain, slipping clutch.. lots of reasons.. need more information and you need to check all the points I mentioned. The clutch is RPM dependant- once the RPM drops- the clutch will start to slip. Look for oil or grease on clutch shoes also
Aug 01, 2014 | Garden
Motor works fine but it appears clutch is slipping , is this repairable? If so where can i get parts. thanks
you could buy a new clutch on ebay or just buy the springs . check your clutch drum bearing sometimes these become worn and will cause your chain to turn and grease it good ,,the clutch drum should spin freely when your saw is shut off and check to see if there is any play in the clutch or noises when you spin it ,,, oh ya you have to take the bar and chain off
Apr 01, 2011 | Garden
The chain slows down or stops when cutting. The engine runs fine and doesn not slow down. I checked the oil, cleared the oil vents to the chain, the brake is fine and is not causing the problem. The...
THE SAW IS RUNNING FINE . WHEN THE CHAIN STOPS AND THE ENGINE IS STILL RUNNING AT HI THROTTLE THE CLUTCH MAY BE WORN AND SLIPPING. PULL THE CHAIN AND BAR AND SEE IF THE CLUTCH HOUSING IS BLUEISH IN COLOR IF SO I WOULD REPLACE THE CLUTCH
Sep 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Mcculloch Pro Mac 700 Chain slips
Make sure the saw is pumping oil to the bar and chain and that the chain turns by hand freely. If ok, is there a sheared or missing key between the clutch center hub and the crankshaft?
Aug 10, 2009 | Garden
Homelite ut-10942-a chain stops under load
Could be the internals of the clutch have been heavily oiled--wash out with carburetor cleaner from an auto parts store. The internals of the clutch expand to the internal rim of the clutch housing when things rev up. Oil blocks the necessary friction needed between those parts. Make sure the chain sprocket is attached firmly to the clutch housing.
Jun 30, 2009 | Garden
CSP 3314. The clutch slips and cannot get a good cut. Any ideas?
Try washing out the clutch interior with carburetor cleaner from an auto parts supplier and blow out with compressed air.
Jun 22, 2009 | Garden
Engine stalls
Sound like the clutch is not disengging. The springs in it are likely week. Take note as to weather the chain stops when it is idleing. If it seem to idle at a reasonable speed and the chain does not stop turning, the clutch is most likely the problem. This problem can be caused by trying to work the saw without the throttle wide open. When the clutch slips it creates heat wich will over heat, and weeken the springs used to disengage the clutch. It is also possible that it was defective when new.
Jan 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
747 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
