Question about Zanussi FJS1225W Front Load Washer
Filter rattleing in front compatment
Filter rattleing , wont drain but will spin?
  • 247 Answers
Assuming that by "filter" you mean the bit behind that little door at the bottom on the front of the machine........
The other thing that's in there is the workings of the drain pump. It sounds to me as if something hard has got in there and is stopping the pump from turning properly.
Turn the power off before you start.
Once you've got all the water out, all you'll need to do is to open up, remove the obstruction and (if it's what I expect it is) buy yourself a drink with it. (There is a big round plug behing the little door. Give it a quarter turn and it will pull out. On some machines, you may have to loosen a small locking screw before the front of the plug will turn)
The tricky part of this is getting the water out when the pump isn't working. The best approach is to pull the machine away from the wall. Put a basin on the floor, then remove the drain hose from the standpipe it plugs into and allow the machine to empty by gravity into the basin. When the basin is about half full, lift the hose up to stop the flow and empty the basin before starting again. This way, you can get the majority of the water out of the machine.
There is always going to be a little bit of water left. The safest way to deal with this is to put cloths down to catch what spills, slide a baking tray under the corner of the machine, and crack open the pump/filter cover (closing it again to allow you to empty the baking tray) - repeating until no more water comes out.
An alternative approach to this last bit is to tip the machine backwards, physically remove the drain pump from the machine (while still connected to all the hoses) and then suspend it over the basin while opening it up. If you know what you're doing, this is much quicker and cleaner than the baking tray approach - but you have to be really careful not to get the electrical bits of the pump wet and not to let the machine topple over onto anybody.
A.
Posted on May 02, 2010
My LG Wahining machine is making a rattling noise and will not spin or drain.
For the washer to spin, it must first drain the water out of the tub. Since you are hearing a rattling noise, and your washer will not drain, most likely the problem is the drain motor itself. The impeller wears out on the shaft, and start to wobble, and make a vibrating/rattling noise.
Sep 23, 2014 | LG WM2487H Front Load Washer
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Doesnt spin on spincylce and just makes a rattling noisewff1475 bosch
The rattling noise is probably something in the pump.
If it is not draining properly, this will stop it spinning.
Check pump filter, if clean, then I would suggest you check the brushes in the motor for wear, as badly worn brushes will also stop it spinning.
Please rate my solution.
Thanks.
Nov 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
Rattling in Kenmore pump
repl/ pump rattling noise is broken impeller in pump reason for no drain and spin
Jul 26, 2008 | Kenmore Elite HE4 Electric Dryer
Front load washer
  1. Turn off machine and unplug it.
  2. Open filter it and clean it.
  3. Check if in pump turbine is clogged or jammed with foreign object. On some pumps you can test if turbine it rotates free using screwdriver or a finger.
  4. Check if the drain outlet pipe is clogged.
Unless pump motor is dead I'm 99% sure that either filter, pump and/or drain pipe are clogged.
Apr 20, 2008 | Washing Machines
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
47 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
