Question about Agfa DC-730i / AP1100 Digital Camera
The on/off button doesn 't run. So i can 't switch from "play" mode to "rec" mode. Camera gets on , only from "play" button. Batteries are not dead. (Camera is brand new...)
Tu change ton clavier
Posted on May 02, 2010
I'm trying to set th time and date on my camera but when I hit the menu button the yellow lock appears how can I get rid of this so I can set time and date correctly please
Hi Keith, The link below is the user manual for the Pentax Optio E30 Digital Camera, On page 56 it says
• In Green Mode, you cannot change the information displayed on the LCD monitor by pressing the 4/W button.
• You cannot use the [A Rec. Mode] menu or Capture Mode Palette in Green Mode. If you try to display the [A Rec. Mode] menu or Capture Mode Palette, - (key lock icon) appears.
• If you switched to Q mode from Green Mode, you cannot display the [H Setting] menu by pressing the 3 button. If you try to display the [H Setting] menu, - (key lock icon) appears.
• When the camera is turned off in the Green Mode, it turns on in the Green Mode next time the power switch is pressed.
THIS IS YOUR CAMERAS USER MANUAL.....CHEERS..
http://www.camera-usermanual.com/manuals/pentax/Pentax_Optio_E30.pdf
Mar 27, 2016 | Pentax Optio E30 Digital Camera
I can't change the language on my Panasonnic DMC-TZ5
Set the REC/PLAY switch to record (the camera icon) and turn the mode dial to the camera icon. Press the button at the center of the cursor pad to bring up the menu. Select the wrench icon, then the speech-bubble icon.
Aug 21, 2011 | Panasonic DMC-TZ5 Digital Camera
Goes from record mode to standby automatically
Wow my friend do you need Ghost Busters? er no this is mostly a case of the main switch being on lock, or the main IC going down on the panel in the cameras brain area, check the locks first, if it is the chip you will need to call your Sony repair man (He will love you) with summer coming he will be able to go on longer holiday, because that wont be a cheap mend sadly.
Number for help then is 01256 828828, now what you will do for cash for your holiday I simply do not know.
Take care, hope it gets sorted out okay?
Jun 04, 2010 | Sony Handycam CCD-TRV57 Camcorder
Video function
An easier way to do this is to just press the right-hand button on the round wheel surrounding the set button. This allows you to scroll through all the various record modes: Snapshot, Bestshot, Video, & Microphone.
Apr 02, 2009 | Casio Exilim EX-Z40 Digital Camera
Samsung s860 digital camera turns on and then goes to blank screen and will do nothing else, to turn off it requires battery removal. same story with new batteries.
Dear customer
thanks for ur inquiry for ur product
If the LCD screen is blank or black when you have your camera in the Camera or Play mode, the camera may need service. To determine if this is the case, follow these steps:
1. Press the Menu button to see if the LCD screen can display the OSD (On Screen Display). 2. Set your camera to Play mode, and then see if the LCD screen displays a picture. 3. To eliminate the possibility of a user setting causing the problem, put the unit into Auto mode by rotating the dial on the units exterior to Auto Mode. Note: The word "Auto" appears on the screen when this mode is activated. 4. If putting the camera into Auto mode does not resolve the problem, test the unit in Play mode. If the unit operates normally in Play mode, but the screen in Camera mode is blank, your camera requires service which you can arrange by Creating a Service Ticket below. Note: Because your camera has an automatic LCD display shutdown feature, its normal for the LCD to stop displaying when the camera has been on for along period of time. This feature prolongs battery life.
urs sincerely
Harrish
Jul 10, 2008 | Samsung Cameras
From chinese to english
Right from Cannon:
Issue:
How do I set the language?
Solution: Procedure for setting the language PowerShot S5 IS.
Setting the Language
The language in which menus and messages are displayed can be selected with this function.
Method 1
  1. Power the camera on in the playbackicon.gif (Playback) mode.
  2. Hold down the <SET> button and at the same time press the <MENU> button.
  3. Use the direction_arrow_up.gif, direction_arrow_down.gif, direction_arrow_lt.gif, or direction_arrow_rt.gif button to select a language and press the <SET> button.
Method 2
  1. In the playbackicon.gif (Playback) mode press the <ON/OFF> button until the power lamp lights.
  2. Press the <MENU.> button to display the Rec. or Play menu.
    - Use the 023.gifbutton to select the setup_icon.gif(Set up) menu.
    - Use the 021.gifor 026.gif button to select LANGUAGE and press the <SET> button.
  3. Use the 021.gif , 026.gif, 023.gifor 028.gifbutton to select a language.
  4. Press the <SET> button.
  5. Press the <MENU> button to redisplay the Rec. or Play screen.
Oct 12, 2007 | Canon PowerShot S5 IS Digital Camera
Can't Get Camera off Standby
may be the rec mode button is set at the anti grounding..usually at sony camera there are 3 switch mode the 5 sec mode, anti grounding and other and always use is the start and stop mode...this switch is located at the side of the camera...
Aug 26, 2007 | Sony Handycam DCR-TRV10 Mini DV Digital...
Error Code EO3 System in Safeguard Mode
Defective mechanism, 03 error states that a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera.
Aug 16, 2007 | JVC 580136 Camcorder
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
Power turns off
I was having the same problem... I put the camera in the cradle with it plugged into usb and then pushed play mode... the camera went to play mode and then i pushed and held the camera mode button while i was removing it from the cradle... it ended up turning on!!! i have no clue.. very weird
Mar 01, 2007 | Casio Exilim EX-Z500 Digital Camera
Agfa DC-730i / AP1100 Digital Camera Logo
65 people viewed this question
Top Agfa Cameras Experts
CHIVOIU...
CHIVOIU...
Are you an Agfa Camera Expert? Answer questions, earn points and help others
