Question about Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt
150 bt blower won't start - Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt
2 Suggested Answers
  • 2895 Answers
SOURCE: Why won't my Husqvarna 150 BT blower shut off? It starts and runs great, but won't kill with the switch.
Kill switch most likely has broken wire between switch and engine. When in "kill" position, it should connect the top of the sparkplug to the rest of the engine. If it doesn't, either the switch is bad or the wire is.
Posted on Jun 15, 2015
My 150 BT hysqvarna blower starts and runs good at first and loses power and stalls after running for a few minutes.changed diaphrams and fuel filter and now does same but doesn't stall
Most people blow air through the carb passages without running something through them to remove the gelled fuel, also these small carbs use Welch plugs that limit access to cleaning carb completely. To do a complete job of it it must be fully dismantled (not air blown through passages) to make it operate correctly again.
Feb 13, 2018 | Cars & Trucks
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
Jun 15, 2015 | Husqvarna 150BT 50CC Gas Leaf Backpack...
How do I return a set of BT phones purchased in February 2014 which have developed a fault
According to BT's website, simply calling 150 (assuming you have a BT landline) will get you through to someone who will be able to sort this out for you.
How do return telephone bought on BT com Help BT com Help
If you do not have a BT landline you can call them on:
  • From a landline: 0800 800 150
  • From a mobile: 0330 1234 150*
  • From abroad: +44 179 359 6931**
Nov 27, 2014 | BT Lands Phones
Husqvarna 150 BT won't start? seems like its not getting fuel.
The blower will need to be checked to see what is wrong. Start with compression, should be 125-145 lbs/in Check spark with a spark tester and make sure to use resistor plug. Next, make sure the fuel lines are in good condition and not cracked or leaking. If the unit has set with fuel in the unit, chances are the carburetor is clogged and the fuel lines are damaged.
Sep 08, 2014 | Husqvarna Garden
My bill
call 150 from a BT land line or 0800 800 150 from non BT lines or mobiles
or
Log in to My BT
May 15, 2014 | Computers & Internet
Husqvarna 350 bt won't start
Do you have good compression, good spark and is fuel getting into the cylinder.? More information would help diagnose the problem.
Jun 03, 2012 | Husqvarna BACKPACK BLOWER 350BT
I have a Husqvarna 150 BT X Torg. It is 2 yrs old & it starts but dies & I start it again but oes the same thing in just a few minutes. HELP
Hi and welcome to FixYa, I am Kelly.
The symptom your describing is most often caused by the primer bulb/pump getting a pin hole in it. See this link Item 17: (PN 544363901)
http://www.partstree.com/parts/?lc=husqvarna&mn=150+BT+(2008-10)&dn=89_55_0033
It can however be caused by diaphragms that have failed inside your WYA-79 carb. If you do not have a primer bulb problem the next step is to rebuild the WYA-79 carb with a diaphragm kit.
net IMAGE search using this: Walbro "WYA 79" "Carburetor Kit" They average $13.99
The carb Manual:
http://wem.walbro.com/distributors/servicemanuals/WYAseries.pdf
Dried and cracked fuel lines can cause the same symptom you describe also.
Thanks for choosing FixYa,
Kelly
Apr 10, 2011 | Husqvarna Garden
I have a Hasqvarna 150BT blower that started to make a knocking noise at full power and has lost some power. Seems to start ok. Loss of power / rpm and knock are only ploblem?
I had the same issue with a Husqvarna 150 BT blower. Brand new ran through 2 tanks of gas and need to buy more gas , mixed 50 to 1 ratio 87 octane on new gas which was the same as what i was running and it started pinging and running like **** then stalled and would not start. took the plug out and it was fouled. cleaned the plug got it running again but still not good. This model comes with a NGK CMS7H plug which i replaced with a champion RZ7C and new gas 93 octane and lawnboy oil mixed 50 to 1 ration and now its running like a champ. I've had bad experiences with NGK spark plugs in the past and thought this may resolve the issue and it did. Hope this is helpful to anyone out there having the same issues. Also used some fuel stabilizer in the fuel mix, I hear this helps with the ethanol problem in the fall/winter gas.
May 13, 2010 | Husqvarna Backpack Blower 25cc, 140 Mph,...
What is the gas/oil mixer on a Husqvarna 150 bt blower?
hi
if you use mixer oil of superior quality 1:50 the ratio mix is 20 ml for 1 liter gas.
regards savumihai71
Dec 16, 2009 | Garden
Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt Logo
631 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
