Question about Kenwood KM300 Chef Stand Mixer
I need to buy whisk attachment for a KM300 - Kenwood KM300 Chef Stand Mixer
Why can't I remove the whisk attachment?
forgot to push up before turning possibly
Mar 21, 2016 | Cuisinart SM-55 Stand Mixer
Kitchenaid whisk will no longer slip past the locking pin to rotate and attach on the spindle.
this might help... the whisk has a slightly larger whole then the other attachments. it is also inset. there is a washer that holds the spring on. if that is slightly off or bent it won't sit in the Whisks inset right. look a little closer to that and the spring. if there happened to be dried on food that could be the slight difference that can prevent it from staying one. Hope this helps!!!
25298509-2el2bftwapqh2uesegcwr3xp-2-0.jpg 25298509-2el2bftwapqh2uesegcwr3xp-2-1.jpg
Nov 27, 2014 | KitchenAid Professional 620 6-quart...
Compatibility of mincer attachment
1) remove the front power outlet of the mixer head.
2) look for a notch in either the top edge or the bottom edge of the casting. (hole)
3) Guide Pin on 9xx accessories is at the top of the connecting shaft.
4) if notch and pin point in the same direction, accessory will usually fit (9xx acc's point up and 7xx acc's point down)
May 30, 2013 | Kenwood KM300 Chef Stand Mixer
Kitchenaid difficulty removing whisk
It is not uncommon for gunk batter sugar eggs or other stuff to get up inside the attachment shaft of the mixer and if you don't use it for a while it can turn to glue. remember school flour and water = glue. well add some sugar and some eggs and "wallah" you got glue. How to fix? Get a squirt gun. yep fill it with hot water and squirt it up in the hook and loop portion of the attachment shaft let it sit for 5-10 mins and repeat a couple times. the beater should come off, clean the shaft and then the whisk soak the attachment portion in hot water and let soak to soften the gunk and the spray it out with the sink sprayer. hope that helps. There could be one other mechanical problem and that is the hook that the beaters hang on could be coming out and caused the attachment to jam up ther take a pencil or pen and while pressing the beater up see if the pin wiggles or wobble and most importantly goes back into the mounting shaft. let us know if this helps at all.
Sep 17, 2012 | KitchenAid Food Mixers
Have a 20 plus year old Kenwood chef [navyblue and white] don't know the model number. When the K beater or whisk are attached they rotate for a few seconds then fall out any ideas what to do
for both attachments to fall out the planet hub must be worn out. check that there is a spring clip in the groove of the beaters. if you have had it repaired recently it may be running backwards which woluld eject the attachments.
Aug 18, 2010 | Kenwood KM300 Chef Stand Mixer
Whisk attachment is stuck on mixer.
I took a small crowbar, and put the curved end up inside the whisk, and hammered the other end lightly. After about 20 taps, the peg was lined up with the sideways opening so I could twist it off. When I got it off, it looked like there was either flour inside the part where the whisk attaches, or some light corrosion was going on. Either way, I'm going to put a little grease in there so it doesn't happen again.
Mar 09, 2010 | Food Mixers
Need a new washer for the liquidiser attachment
Hi you can get the washers in Ebay, or in 4kenwood.co.uk
also check what model its your liquidiser, A700 , A900 or AT
regards
Sep 03, 2008 | Kenwood KM300 Chef Stand Mixer
SILLY QUESTION
Push the whisk attachment post up into the mixer, turn counter-clockwise and it should lock into position.
Apr 03, 2008 | Kenwood KM800 Major Classic Stand Mixer
How do I remove and refit a motor to my KM300?
What you need is a service manual which is difficult to get for any Chef regardless of the KM300. Ive got a KM310 model but the user manual is similar to this if it helps:
http://www.kenwoodworld.com/datasheets/KM336--KW89421iss2%20KM330-KM630%20%20English%20-0.pdf
Sep 11, 2007 | Kenwood KM300 Chef Stand Mixer
Kenwood KM300 Chef Stand Mixer Logo
96 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
Treefrog15
Treefrog15
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
