Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Cannot find model I am looking for Kenmore 78302 23 cuft - but the refrigerator will not run. Circuit breakers checked and reset plugs checked. Is there anything else I can do? Only two years old.
Krazytech
  • 725 Answers
SOURCE: Kenmore Model #731893 Room Air Conditioner
Does you air conditioner have a GFCI on the end of the plug if it does there is a reset there.. let me know if it doesn't and you want to go deeper?
Posted on Aug 24, 2007
fridgetech
  • 473 Answers
SOURCE: Refrigerator Running Warm
It has a defrost problem.  3 things could be the problem.  1. Defrost thermostat  2. Defrost timer  3.  Defrost heater.  The timer is in the fridge section in the middle of the console behind the controls.  On that console you will see a little hole that will give you access to the timer gear that can be turned clockwise (slowly until it clicks) to put it into defrost.  Take the back panel off in the freezer.  Once you have put it into defrost see if the defrost heater comes on behind that panel in the freezer.  If it comes on then the timer is bad.  If the heater doesn't come on then it is most likely the defrost thermostat which clips onto the evaporator behind the freezer panel.  It's less likely, but it could be the defrost heater itself but it can easily be tested with an ohm meter for resistance.  Any resistance means it's ok.  Let me know if you need further assistance.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
  • 537 Answers
SOURCE: Kenmore 60 series washer
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on Dec 07, 2007
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
shaggyrat
  • 1224 Answers
SOURCE: Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Posted on Jun 01, 2008
My Kenmore refrigerator 795.7830 stopped working, I have checked the plug and it is fine. No lights or compressor or error code
Hello
Check your home circuit breaker and the wall outlet.. try plugging in another appliance into the outlet to see if it works.
Listen carefully to the fridge for a two or three minutes. If you hear a buzzing and click sound.Then power is getting to the compressor but it isn't running the refrigerator. You may have to replace the compressor
Jun 04, 2015 | Kenmore Refrigerators
Kenmore refrigerator/freezer not cold! I have a Kenmore Coldspot model 57572791 refrigerator/freezer that suddenly stopped cooling/freezing. I took off the back & think it is the compressor @ the...
It is not likely, but since you had the lights on the same circuit it is possible that the breaker for that circuit may be tripped. Have you checked the breaker?
Jan 21, 2013 | Kenmore Refrigerators
KENMORE DEHUMDIFIER MODEL 580.51300100 DOES NOT RUN, NO POWER LIGHT AND NO FAN RUNNING ETC
First, check the source of the power to the unit, Has a circuit breaker in your home's circuit breaker panel been tripped? If so, unplug the unit, before resetting the circuit breaker. If that's not the case, check the outlet it's plugged into. It may be damaged or have a loose wiring connection. Be sure to turn the circuit breaker for that receptacle OFF, before removing the cover plate.
If all of the above checks out OK, check the water collection bucket, as it may need to be emptied and/or the bucket was not reinstalled properly or the float valve in the top of the bucket is stuck in the UP position, If so, jiggle the arm of the float valve to get to return to the DOWN position.
When reinstalling the bucket, be sure that it fits "squarely" into it's holder and makes firm contact with the bucket safety removal switch.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 13, 2011 | Kenmore 54501 Dehumidifier
. I have a Kennmore Coldspot Fridge that runs for
A 15A circuit is mainly reserved for lighting.
Even some vacuum cleaners would trip a 15A circuit breaker.
The problem isn't with your refrigerator...its with the breaker installed in the breaker box.
Check your wire size and follow these rules :
12 gauge wire can have 30A c/b max
14 gauge wire can have 20A c/b max
16 gauge wire can have 15A c/b max
So, if the wires coming out of the wall socket is 12 gauge or even 14 gauge...you should be able to swap that 15A circuit breaker with a 20A circuit breaker.
This should be plenty for your refrigerator...if it "pops a 20A"...then you've got appliance problems.
If you don't feel comfortable doing that...then get a new 15A breaker...because it sounds like the other one has gotten weak.
Hope this helps
Jul 23, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Frig keeps overloading circuit breaker, just repaced relay
I think the compressor has a problem with its internal running coil , or it's grounded.To check it you can disconect the power to the compressor and then turn on the breaker , and if doesn't tripped the breaker ,you know the compressor is bad.
Sep 06, 2009 | Refrigerators
New Kenmore refridgerator trips circuit breaker
1. Check to make sure the receptacle is wired correctly. Black wire goes smaller of two inlet holes, white goes to the larger.
2. Check to make sure that the smaller blade of the 2 prongs on the ref. plug is not grounded. Use ohmmeter from smaller blade to fridge housing
Apr 25, 2009 | Kenmore Refrigerators
My Amana refrigerator freezer is totally off.
Ouch!
You may have lost your fridge. Try This.
  1. Unplug.
  2. Take a table lamp & plug into socket where you had fridge plugged in. Turn light on. If it lights. Fridge is trouble.
  3. If no light check another socket make sure light works if it works your socket, wiring or breaker is your problem.
  1. If fridge check wire to & from fridge make sure it is unplugged feel & look for crimp or gap in wire.
  2. Check connection to fridge some have a reset button or overload fuse. Reset or replace if you find one.
  1. If socket try another socket see if fridge runs.
  2. If it runs you will have to troubleshoot house wiring.
Contact me if you need more help. Good Luck!
Please rate if this fixed or was helpful. Thank you.
Mar 09, 2009 | Amana ABB1927DE Bottom Freezer...
Kenmore side by side refrigerator (model 50542001)
THE SUSPECT YOUR COMP HAS LOCKED UP AND IS TRIPPING THE BREAKER,IF YOU HAVE A METER YOU CAN CHECK THE AMP DRAW,LOOK ON THE COMP. AND YOU WILL SEE THE LRA DRAW-MIKE
Mar 01, 2009 | Kenmore Refrigerators
Kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Dec 04, 2007 | Kenmore 84072 Electric Dryer
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
