Question about LG LW7000R Air Conditioner
My AC is extremely loud and vibrates the entire house. Is it supposed to do this. I have 4 other ACs in my house and none of them do this. Sometimes the fan blows and that's fine but then it charges and blows the cooler air and the whole house shakes . I bought it last spring for the baby's room and hardly used it but then my daughter was born and its way too loud to sleep next to.
    Champion:
  • 225 Answers
No its not suppose to do this,the pump has a broken spring in side it which creates the viberation,unfortunatly the pump is a sealed unit so it can not be repaired.you have to replace the pump,cashie,probably be cheaper depending on age of unit to buy another a c unit.
Posted on May 02, 2010
2 Suggested Answers
  • 82 Answers
SOURCE: my ac is extremely loud and vibrates the entire
This will need to have the compressor mounts checked...If fan only operation is smooth...and only happens when compressor is on, is a direct sign of vibration off compressor. Check the rubber foot mounts under compressor.....of course this requires removal and cover taken off
Posted on May 10, 2010
Ac fan is making extremely loud noises
Are you referring to the blower motor inside the car? If so, they get leaves in them which puts them out of balance and makes them noisy. Just take out the blower, 3 screws, and clean it. That's the cheap answer. It can be a bad blower motor.
Jul 07, 2014 | 1999 Honda Civic
I have a 94 Dodge 1500 p/u. Water from ac is draining into cab. Entire acs system just replaced
the drain from the box is clogged, Not a shot they replaced it if water is in your cab, unless the box is busted?
Jun 18, 2010 | Cars & Trucks
My ac is extremely loud and vibrates the entire house. Is it supposed to do this. I have 4 other acs in my house and none of them do this. Sometimes the fan blows and that's fine but then it charges and...
May 10, 2010 | LG LW7000R Air Conditioner
After compressor on,Sears/Kenmore ac makes a loud vibration noise
sounds like head pressure problem it is most likely clogged on condenser try washing out really good then try again
Sep 10, 2009 | Heating & Cooling
I have three window ACs in my entire mobile home(double wide). One at the back of the house, one in the middle and one in the front. Each one is plugged into its own outlet. If I try to run more than one...
Susan; # A/C units in a mobile hme is a little much to much. I'm surprised it hasn't burned down. Upping yor circuit breaker would cause an extreme fire hazard.
Jul 10, 2009 | Gibson Thru-Wall/Window Air Conditioner
I am working on a problem with a '93 corolla. When at idle with the AC off there is a slight vibration but the engine RPM is about normal, after turnig the ac on and the clutch engages the vibration gets...
heres what ive seen happen. There is an aluminum hub that the new clutch slides onto. it has a groove in the end 4 a snap ring to keep the clutch from sliding off obviously. when you try to slide your old clutch off past that "ring land" it almost everytime breaks!(thin aluminum casting) so you may need compressor anyway. But more than that toyota had a special idle up circuit dedicated to just a/c and it would carbon up and fail--so you probably dont need a compressor any way. look at that first
Apr 08, 2009 | 1993 Toyota Corolla
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Speakers Died?
No, I think you've fried only the fuse of Altec Lansing. Check at the back of the main unit (subwoofer) if there's a fuse box (should look like head of the plastic bolt). If not than turn it off, unplug it and open op the main unit and check for the fuse. It should look like this:0a68355.jpg
If the metal wire inside of it is broken than you should buy new fuse of same amperage (it should be engraved on metal part of the fuse or printed on glass tube).
Apr 21, 2008 | Altec Lansing ACS 45.1 Computer Speakers
LG LW7000R Air Conditioner Logo
217 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
