Question about Nokia N70 Cellular Phone
Can't switch N70 to online mode. when I switch set off then on again it bypasses PIN requirement and goes straight to active screen which shows 'OFFLINE' mode
Thank it works
Posted on Sep 05, 2010
  • 229 Answers
Change setting in phone settings or call setting. you will get change flight mode, send my no, caller id. you just have change yes to no. or no to yes.
Tenzin
Posted on May 02, 2010
How can i removed icloud locked in my iphone 6.i dont have the password
The answer was already here:
Unlock iCloud iPhone 6S, iPhone 5S, iPhone 7, iPhone 6S+, iPhone plus
Download from:
http://unlock-icloud.com
Unlock and remove iCloud for:
All iOS
iPhone 7
iPhone 5S
iPhone 6
iPhone 6 plus
iPhone 6S
iPhone 6S plus
All iPad's and new models
Remove iCloud activation lock, bypass iCloud lock
Real and working by software, work on all Apple iPhones
Trusted solution work 100% i recommand it's verified!
The software is easy to use and the support team from unlock-icloud.com offer good technical support with team viewer and video for unlock icloud and iphone repair solutions. The signal work excelent after i have used this software. The software is clean no viruses or other bad things like other software from internet.
With this software i managed to repair my iPhone 6 iCloud errors and bypass activation lock. It's a realy gsm repair tool.
Oct 25, 2016 | Cell Phones
How do i bypass the apple id activation on my iphone 6?
iCloud Locked iPhone 6 How to bypass iCloud Lock on iPhone 6
So, in this post, I would like to show you 4 solution about iPhone activation bypass
Solution 1. Remove iCloud Activation Lock from your iPhone 6 with Unlock Tool
Solution 2. Bypass iCloud Activation Lock Software via iCL0udin
Solution 3. Bypass iCloud Lock via Apple Setting
Solution 4. Bypass iCloud activation online with iCloud Lock Removal Service
Sep 19, 2016 | iPhone Apps
HOW CAN I ACTIVATE MY IPHONE 5S WITH OUT USING APPLE ID IN ACTIVATION MODE
you cannot bypass this screen because it means that the phone was either lost/stolen/ or the password has been forgotten now if you got it fro ma friend how them active it again then delete the account in the settings
Feb 18, 2015 | Apple iPhone 5S
My N70 shows white display but other activities it works properly. ones you disconnect the display and again reconnect the same, the display will work for 2 to 3 days and again same problem...
first format your phone by using this code
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
after this process the problem continuous , please check and change your mobile display with the help of an expert mechanic ,
most of the n70 users facing these problem
thank you
please rate me if my opinion helps you
Oct 18, 2010 | Nokia N70 Cellular Phone
Windows is activated but will not let me log in
dear,
switch to Safe Mode and then delete the login except the administrator one...then try again..
hope it will work..
regards,
May 11, 2009 | Microsoft Windows XP Home Edition
Locked phone n70
hi there,
here you try to follow some procedure how to unlocked your mobile and i hope it will help you to solved it..
any further question you can log on this site....
http://gleez.com/articles/did-you-know/nokia-secret-codes
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
Thanks.
Feb 17, 2009 | Nokia N70 Cellular Phone
Monitor shows screen then goes black
It is the Monitor Cable connected to the CPU cabinet is faulty. Please check out the cable and its pin firmly.
Try to find the fault, may be the cable broken or tear up.
Let me know if further diagnose required.
Have a nice day.
Ellin
Oct 14, 2008 | Hyundai ImageQuest Q15 15.1" Flat Panel...
N70 lcd display
It is a common problem of NOKIA N70.
Switch off your phone.
Remove the battery & sim card.
After some times (30 minutes) set them again & switch on.
Leave the phone for a while it will automaticly in order.
Jun 16, 2008 | Nokia N70 Cellular Phone
No signal
do a network settings check and see if thaht helps, if not try servicing the phone.
Feb 29, 2008 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
380 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
